rvnmaniac Posted June 24, 2017 Share Posted June 24, 2017 Okay last night my Break & Battery light came on and i lost power steering. The pic shows what i found left of the belt this morning. Looking for suggestions on the best belt and part # since i've seen enough posts where some have purchased the wrong belt. THANKS 2009 2.5I SE Legacy Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted June 24, 2017 Moderators Share Posted June 24, 2017 Just go to advance auto and have them look up what belt you need. Brand really shouldn't matter much. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Max Capacity Posted June 24, 2017 Share Posted June 24, 2017 Yep, any brand belt from the local auto parts store is fine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rvnmaniac Posted June 25, 2017 Author Share Posted June 25, 2017 Problem solved and belt replaced. Anyone needing a part # for future use. I went with a DAYCO Product SKU: 5050345 Nice to have power steering back.... Link to comment Share on other sites More sharing options...
rvnmaniac Posted June 26, 2017 Author Share Posted June 26, 2017 What do folks use as a guide to know whether the belt is tight enough. Looking at the adjuster screw I didn't adjust as far down as it previously was. You can see the cleaner portion of the screw. To me it feels fine but I will keep an eye on it. Maybe that was the problem... whoever previously dealt with that belt may have over tightened it. I'm thinking it may have been the original belt though. The car now has 64K miles. I just purchased the car January this year... Link to comment Share on other sites More sharing options...
Max Capacity Posted June 26, 2017 Share Posted June 26, 2017 I think you should have 1/4" to 3/8" play when you push down on the belt. If your PS feels funny, tighten the belt a bit. Learned that lesson. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
