ThatOneGuy Posted September 30, 2013 Share Posted September 30, 2013 I'm fresh to this whole forum website, so I don't know if I'm posting in the correct forums, but I did a wing delete on my 06 Legacy, and it left pretty nasty holes. I unfortunately can't afford to buy a wingless trunk and paint it, and nobody around my area would be interested in trading. I was thinking I could use Bondo to fill the holes and use touch up paint that matches my paint code to paint over the bondo to make it blend in. Does anyone have any other/better suggestions? Money is tight right now, nothing outrageous please Link to comment Share on other sites More sharing options...
cseagle08 Posted September 30, 2013 Share Posted September 30, 2013 Bondo will not stay in place over much time with no backing behind it (for example open hole). If anything you could get a small piece of sheet metal tack welded on the back side of the holes, then bondo in the holes smooth. Maybe even use jb-weld to secure the sheet metal if you don't have access to a mig welder. Thinking on a budget here that'd probably work. Link to comment Share on other sites More sharing options...
ragman Posted October 1, 2013 Share Posted October 1, 2013 Bondo only with touch up paint will never work. If your looking for the easiest way to plug the holes, without real paint work, I'd search for some sort of rubber/plastic plugs. Link to comment Share on other sites More sharing options...
Code Posted October 1, 2013 Share Posted October 1, 2013 PM famaya, he's got this one figured out. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
urabuslegacyGT44 Posted October 1, 2013 Share Posted October 1, 2013 you could also tape off the holes so you don't have imprints, then vinyl wrap just the top of the trunk lid. Link to comment Share on other sites More sharing options...
ThatOneGuy Posted October 1, 2013 Author Share Posted October 1, 2013 you could also tape off the holes so you don't have imprints, then vinyl wrap just the top of the trunk lid. I'm not too familiar with the vinyl wrap, how would I know what/where to get it and how would I know what color I need to match my car? Link to comment Share on other sites More sharing options...
JermTheElf Posted October 1, 2013 Share Posted October 1, 2013 carbon fiber wrap it bro Link to comment Share on other sites More sharing options...
quick4dr Posted October 1, 2013 Share Posted October 1, 2013 +1 for vinyl wrap it Link to comment Share on other sites More sharing options...
m sprank Posted October 1, 2013 Share Posted October 1, 2013 We cut small "patches" of metal and tig weld them over the holes (patch from the bottom, weld from the top). Then we grind down the welds smooth and glass over them. Works like a champ. Can paint or wrap from there with confidence that the holes will not "sink", "pop out", leak or worse. Link to comment Share on other sites More sharing options...
ThatOneGuy Posted October 2, 2013 Author Share Posted October 2, 2013 Also, how would I get rid of the residue built up around the holes without damaging the paint? Link to comment Share on other sites More sharing options...
robinlsb Posted October 2, 2013 Share Posted October 2, 2013 Also, how would I get rid of the residue built up around the holes without damaging the paint? See Mr Sprank, if you want it done right;) "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
m sprank Posted October 2, 2013 Share Posted October 2, 2013 There is no way to properly fill the holes without "damaging" the paint. Vinyl wrapping a trunk lid (professionally) in my neck of the woods is $200-$250 (depending on vinly choice). Paint is more than twice that for a "decent" paint job. Link to comment Share on other sites More sharing options...
