Tehnation Posted March 11, 2013 Share Posted March 11, 2013 Me and friend installed downpipe and uppipe, and the bolt that goes in uppipe bung shot out and burnt my maf wires. Now it wont start, any ideas? I am repairing wires right now but i had separated them and tried starting but still same thing. Link to comment Share on other sites More sharing options...
Tehnation Posted March 11, 2013 Author Share Posted March 11, 2013 So can I use my laptop/vagcom to just reset the ecu? Anyone know how to use laptop to do this or which program? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 11, 2013 Share Posted March 11, 2013 Pull the negative battery cable for about 15 minutes. The engine will crank for about 10 seconds before it fires 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted March 11, 2013 Author Share Posted March 11, 2013 Tried that. Nothing. Thermostat stays pegged. Link to comment Share on other sites More sharing options...
silen7guardian Posted March 11, 2013 Share Posted March 11, 2013 You could check your fuses. Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted March 11, 2013 Share Posted March 11, 2013 er hc... that means you fried your computer.. mine said same thing when I tried to flash using a cobb that had a bad cable.. if you have a cobb or something try reflashing your map to it Link to comment Share on other sites More sharing options...
Tehnation Posted March 11, 2013 Author Share Posted March 11, 2013 Just checked fuses didnt find anything. Tried connecting my laptop but it wont connect. I never flashed my ecu before, so I am finding it hard to believe it just fried from the maf wires shorting out. Link to comment Share on other sites More sharing options...
Tehnation Posted March 11, 2013 Author Share Posted March 11, 2013 Cant seem to get car into diagnostic mode. Any way to reset it? Link to comment Share on other sites More sharing options...
Tehnation Posted March 11, 2013 Author Share Posted March 11, 2013 How would I go about replacing ecu? Link to comment Share on other sites More sharing options...
Tehnation Posted March 11, 2013 Author Share Posted March 11, 2013 Anyone have any ideas, sitting on side of road posting from phone so i am having trouble finding more info. Link to comment Share on other sites More sharing options...
Tehnation Posted March 11, 2013 Author Share Posted March 11, 2013 Are ecus plug and play, lol. Link to comment Share on other sites More sharing options...
Tehnation Posted March 11, 2013 Author Share Posted March 11, 2013 Got the er hc to go away. But car still wont crank. Link to comment Share on other sites More sharing options...
silen7guardian Posted March 12, 2013 Share Posted March 12, 2013 Once you've hear back from the dealership, I'd be curious to know what they said. Link to comment Share on other sites More sharing options...
MAP Posted March 12, 2013 Share Posted March 12, 2013 Try disconnecting the MAF sensor then cranking... You might have shorted something internally to the MAF sensor causing the ECU to shut itself off. I had that happen with a CPS a while back on a different car. The sensor shorted internally causing the ECU to shutoff.(got NO BUS message on dash) Once I disconnected the sensor, the no bus message disappeared and gauges were OK. Replaced the sensor and all was fine. Link to comment Share on other sites More sharing options...
Tehnation Posted March 13, 2013 Author Share Posted March 13, 2013 The heat must have wreaked havoc on that wire harness, I will find out tomorrow whats going on. Being that they are still looking and had to call me to ask what the hell was goin on with my car because of all the aftermarket mods, I assume the ecu is probably ok, because they would have stopped right there. But cant say for sure, just hoping! 110 dollars to find out why it doesnt start, thats gonna be a well earned 110! Link to comment Share on other sites More sharing options...
Tehnation Posted March 13, 2013 Author Share Posted March 13, 2013 I believe they said on phone line 4 blow a fuse and one of wires in maf sensor was pulled. 220 to diagnose and fix..... BAH, I pulled every fuse and still did not find it.... Is there a fuse location I could have overlooked? I pulled all the fuses near driver seat and my buddy "supposedly" checked all the ones under hood.... Good thing he said, he will split the bill if its a fuse, no way its a fuse!!! I like when people put their money where their mouth is, SCORE! Link to comment Share on other sites More sharing options...
Max Capacity Posted March 13, 2013 Share Posted March 13, 2013 Not a bad cost for that much trouble shooting and headache. Consider yourself lucky. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted March 13, 2013 Author Share Posted March 13, 2013 Already am!! Link to comment Share on other sites More sharing options...
