dvto2 Posted May 11, 2018 Share Posted May 11, 2018 I have a 2002 legecy sedan my son uses at college. It started misfiring and the obd says both cylinders 3 and 4 ste misfiring. Which cylinders are 3 and 4? Thanks Link to comment Share on other sites More sharing options...
Brighton96 Posted May 11, 2018 Share Posted May 11, 2018 The two rearward ones (I think) Passenger side is 1 and 3 and driver side is 2 and 4. Link to comment Share on other sites More sharing options...
dvto2 Posted May 11, 2018 Author Share Posted May 11, 2018 So 3 and 4 are the two front cylinders? Link to comment Share on other sites More sharing options...
Brighton96 Posted May 11, 2018 Share Posted May 11, 2018 So 3 and 4 are the two front cylinders? Nope, they're the rear two, closest to the firewall. The 1 and 2 are the ones closest to the radiator. Sorry, I realized I worded that in a confusing way haha http://legacygt.com/forums/attachment.php?attachmentid=210590&d=1434124477 Link to comment Share on other sites More sharing options...
dvto2 Posted May 11, 2018 Author Share Posted May 11, 2018 Thanks! Link to comment Share on other sites More sharing options...
RustyRuu Posted May 11, 2018 Share Posted May 11, 2018 tell him to switch the wires around and see if the codes follow to different cylinders and it could just be the wires, nice and free way to check. Link to comment Share on other sites More sharing options...
RumbleRumble Posted May 13, 2018 Share Posted May 13, 2018 tell him to switch the wires around and see if the codes follow to different cylinders and it could just be the wires, nice and free way to check. No you can't switch wires around they are labeled for a reason Link to comment Share on other sites More sharing options...
Osei Posted May 13, 2018 Share Posted May 13, 2018 What reason is that? O. Link to comment Share on other sites More sharing options...
Brighton96 Posted May 14, 2018 Share Posted May 14, 2018 What reason is that? O. Because they're labeled and switching them would make the labels inaccurate Link to comment Share on other sites More sharing options...
doublechaz Posted May 17, 2018 Share Posted May 17, 2018 What is the maintenance level on this car? If it isn't so well maintained I'd start with suspecting the plugs and wires. If it is well looked after I'd switch my first thought to the coil or jumped timing. I got some 3 and 4 misfire codes when my timing was jumped. They were mostly at idle. Link to comment Share on other sites More sharing options...
eagleeye Posted May 18, 2018 Share Posted May 18, 2018 the typical NGK copper plugs on these only last 30,000 miles. (my H4 has NGK double plats, as they are so small the price is still cheap for something so much better). ________ but as its 3 and 4: what kind of coil does it have. ones of this year should say "subaru" in small letters etched on the front. aftermarket ones can be JUNK. (might last a few thousand miles and then fail). ...and then some of them are even more expensive the OEM. I would even consider getting a used one for $20 out of a pick and pull as the OEM lasts so long. Link to comment Share on other sites More sharing options...
Osei Posted May 20, 2018 Share Posted May 20, 2018 As originally stated by RustyRu, tell him to switch the wires from no 1 plug to number 3 and number 2 plug to number 4. Clear the codes by disconnecting the battery if he doesn't have access to a scanner and then run again. If the misfires are now on 1 and 2. its the wires. If they stay on 3 and 4 its probably the coil, Alternatively if he can use a multimeter there are resistance values for the cords and the coil. Oignition coil and ignitor assembly.pdfspark plug cord.pdf Link to comment Share on other sites More sharing options...
Setnev Posted May 22, 2018 Share Posted May 22, 2018 I'd check the resistance values on the coil per the first PDF that Osei uploaded. Makes quick work if you have a multimeter. If you don't have one, buy one. I used to have a cheap $5 one from HFT that served it's purpose, but I realized a long time ago how important having a good one is, so I bought one of the expensive ones from HFT a few years ago and it's still going on it original battery. Link to comment Share on other sites More sharing options...
RumbleRumble Posted June 20, 2018 Share Posted June 20, 2018 What reason is that? O. you'll get a misfire.... Link to comment Share on other sites More sharing options...
Osei Posted June 22, 2018 Share Posted June 22, 2018 you'll get a misfire.... I think you are unaware of some basic electricity and logic. Just ask any electrician or mechanic. If the misfire follows the wire, then the wire is bad and you've probably found your source. You won't create a misfire by using a labeled 2 wire on any other cylinder as long as it reaches. Try it. O. Link to comment Share on other sites More sharing options...
RumbleRumble Posted July 6, 2018 Share Posted July 6, 2018 Nope. If you want I'll make you a video. each wire has a different timing for firing order. nvm I was thinking you were still leaving it on the coilpack and just swap it from plug to plug..... Link to comment Share on other sites More sharing options...
