ZX2Fast Posted April 10, 2013 Share Posted April 10, 2013 My 1997 Legacy L seems to have trouble charging the battery with the a/c on full and the headlights turned on. At idle I'm getting down to 12.5 volts. The battery and alt have been tested and test good. I do plan to do a ground upgrade (that alone might solve the issue) but in case that doesn't work out, I wondered if there was a bolt-on alt upgrade for this car. It has the 2.2 single port engine. I plan to add a power-inverter so simply putting an overdrive pulley on the existing 85amp alt isn't going to cut it. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted April 10, 2013 Share Posted April 10, 2013 First check all of your grounds. When you have any electrical issue, that's where you start. On top of that, why not install an engine bay grounding kit. Your electrics will end up running much better because of it. Stock grounding is terrible. Link to comment Share on other sites More sharing options...
Whatisit Posted April 10, 2013 Share Posted April 10, 2013 First check all of your grounds. When you have any electrical issue, that's where you start. On top of that, why not install an engine bay grounding kit. Your electrics will end up running much better because of it. Stock grounding is terrible. google "big 3 upgrade" and you should get alot of info on what wires to upgrade. If your wires are fine and you still need an alternator (with high output) check out http://www.maniacelectricmotors.com/hiou195ampsu.html . I have the 140 amp unit and its way overkill for my oem needs Link to comment Share on other sites More sharing options...
ZX2Fast Posted April 13, 2013 Author Share Posted April 13, 2013 I intended to clean up the factory grounds and add a 4 gauge wire between the batter + to alt, battery ground to body, battery ground to engine, engine to body. If that doesn't work I'll upgrade the alternator. Link to comment Share on other sites More sharing options...
Hemingway Posted April 13, 2013 Share Posted April 13, 2013 Wow, you know you have a serious alternator when it recommends a 100 amp in line fuse! Link to comment Share on other sites More sharing options...
spooln30 Posted April 14, 2013 Share Posted April 14, 2013 Any rebuild shop should be able to upgrade the amperage. There's a few shops in the Milwaukee area that rebuild alt, starters, electric motors etc. There should be one near you just google it or check your yellow pages. LOL. If you still even get them. Link to comment Share on other sites More sharing options...
stevenva Posted April 18, 2013 Share Posted April 18, 2013 You can save some money and use welders cable as opposed to car audio cable. Better quality and cheaper. DC Power Engineering also makes alternators for Subies. https://www.dcpowerinc.com/high-output-alternators/hp-series-high-output-alternators.html?make=Subaru&model=Legacy&year=1996&engine=2.2L+H4 Here's one in my car. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
Hemingway Posted April 18, 2013 Share Posted April 18, 2013 Awfully pretty looking alternator Link to comment Share on other sites More sharing options...
vinnycogs Posted April 18, 2013 Share Posted April 18, 2013 Steven can you tell me what kind of intake you have/how to install? Also do you like the coilpack? Link to comment Share on other sites More sharing options...
Zues Marine Posted April 18, 2013 Share Posted April 18, 2013 Steven can you tell me what kind of intake you have/how to install? allow me.. 1. Buy Car 2. Done! Link to comment Share on other sites More sharing options...
stevenva Posted April 18, 2013 Share Posted April 18, 2013 Steven can you tell me what kind of intake you have/how to install? Also do you like the coilpack? ?Intake? As far as the coil goes-There was no large difference. The small improvement will be credited to the new plugs and wires I did at the same time. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
Zues Marine Posted April 18, 2013 Share Posted April 18, 2013 i think he meant the tube, its not the big box the 2.5s have Link to comment Share on other sites More sharing options...
stevenva Posted April 18, 2013 Share Posted April 18, 2013 It's still an odd question. In his sidebox info, it says he's got a 2.2. (is the 98 intake different from a 96) RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
ZX2Fast Posted April 19, 2013 Author Share Posted April 19, 2013 My Legacy had the cancer box on it. I ended up getting a 1st gen intake at the yard and I like the intake box/tube on the 96 LGT parts car better so I'll be swapping it out again. Link to comment Share on other sites More sharing options...
vinnycogs Posted April 19, 2013 Share Posted April 19, 2013 Yeah sorry I thought you had an aftermarket one Steven. I have a 98 2.2 and i have the giant box (apparently called cancer box). What does it do? Does a straight tube to the MAF sensor thing work better? Link to comment Share on other sites More sharing options...
stevenva Posted April 19, 2013 Share Posted April 19, 2013 Cancer box, I don't know what it does. Perhaps it is some kind of resonator? 2nd question= I doubt it. Rarely do people re-design something to perform worse. Although I'm sure everyone can think of an example. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
pleaidestar Posted April 19, 2013 Share Posted April 19, 2013 Boy that is a nice alternator, cost is about the same as a Fuji stock alternator. Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 19, 2013 Share Posted April 19, 2013 For me, with no electronics, id stick with the fuji heavy all day Link to comment Share on other sites More sharing options...
pleaidestar Posted April 19, 2013 Share Posted April 19, 2013 That's what I'm saying, that's nice as far as aesthetics by you can take the shell off the Fuji alternator to polish and anodize at a chromeshop. Link to comment Share on other sites More sharing options...
Zues Marine Posted April 19, 2013 Share Posted April 19, 2013 Yeah sorry I thought you had an aftermarket one Steven. I have a 98 2.2 and i have the giant box (apparently called cancer box). What does it do? Does a straight tube to the MAF sensor thing work better? In theory the torquebox holds a reservoir of air ready to go into the throttle body the moment it opens. We know a vacuum is created on initial TB opening. Apparently the box helps alleviate that and in doing so increases torque and throttle response. Link to comment Share on other sites More sharing options...
ZX2Fast Posted April 20, 2013 Author Share Posted April 20, 2013 Where did you read that theory? Is that what Subaru says or are you guessing? I removed all that crap from my L and even without telling my wife about it, she noticed better throttle response and better low-end power and asked what I had done to the car. That was the only change I made. Looking at this intake on the 96 LGT it looks even better then the intake I got of a 1st gen wagon at the yard. The entrance to the MAF is longer so the signal shouldn't be a choppy and I like the quick release clamps better than the screw-on box so I'll be swapping that out soon. I also removed that lower air resonator and will probably be making a lip for the box so it draws air only from the fender well and not any from the engine bay. Link to comment Share on other sites More sharing options...
Zues Marine Posted April 20, 2013 Share Posted April 20, 2013 that's the Subaru intention of that box.. but.. the 'ribbed' style J-pipe, intake tube off of 2nd gen. OEM 2.2s until... maybe 97ish(?), is the one you want, that delivers the most performance gain Link to comment Share on other sites More sharing options...
ZX2Fast Posted April 21, 2013 Author Share Posted April 21, 2013 I got one off a 92 Legacy and the 96 LGT looks to be the best design. My 97 Wagon had the cancer box on it. Not sure how Subaru thinks that box holds air in reserve when we have a planet and atmosphere full of air. Link to comment Share on other sites More sharing options...
