linuxbatm Posted March 9, 2015 Share Posted March 9, 2015 Searched and didn't find much wagon love. Any suggestions on where to put a satellite antenna on a wagon? I ordered an inside windshield mount antenna but I am not sure how good the reception will be. Any other suggestions inside the car? I hate punching holes in grommets to snake antenna wire through. Link to comment Share on other sites More sharing options...
robinlsb Posted March 9, 2015 Share Posted March 9, 2015 Searched and didn't find much wagon love. Any suggestions on where to put a satellite antenna on a wagon? I ordered an inside windshield mount antenna but I am not sure how good the reception will be. Any other suggestions inside the car? I hate punching holes in grommets to snake antenna wire through. I have had 2 xm antennas installed on my wagon.The best is one installed on the back of the roof(lots of wire) The one installed on the front,tended to die,because even a little part of the wire,exposed to wind,would wobble, and in the end would fail. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
c-lo Posted March 9, 2015 Share Posted March 9, 2015 yep. mine is tucked in the liner all the way to the back and sits in the center by the edge of the roof line and tail gate 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
Max Capacity Posted March 9, 2015 Share Posted March 9, 2015 In my Spec B I just stock it to the upper part of the windshield next to the EZ-Pass. You can mount it inside the car under the metal ? didn't know that. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MrTris Posted March 9, 2015 Share Posted March 9, 2015 In my Spec B I just stock it to the upper part of the windshield next to the EZ-Pass. Same. Tore mine out, including off of the roof and through the passenger A pillar - Link to comment Share on other sites More sharing options...
linuxbatm Posted March 9, 2015 Author Share Posted March 9, 2015 Thanks all. I will give the window mount a try and see how reception works. What antenna are you guys using that have it stuck to the window? The OEM one? Link to comment Share on other sites More sharing options...
BX77 Posted March 10, 2015 Share Posted March 10, 2015 Center dash board next to windshield Link to comment Share on other sites More sharing options...
tonybuttons Posted March 10, 2015 Share Posted March 10, 2015 I have mine on the dash. Cuts out where it would normally cut out, under dense trees, bridges, etc. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 10, 2015 Share Posted March 10, 2015 Mine is the OEM kit. It cuts out the same places my GF's Ford Escape does. Her's is mounted to the top of the roof. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
