denokarter Posted February 27, 2021 Share Posted February 27, 2021 Right after filling up gas...turned car back on..." At Oil Temp" appeared on the dash. Car drives fine. Anybody have this issue before? Seems to be in regards to transmission temperature just searching on google. 100 000 miles on my 2015 Subaru Legacy, I have yet to change the CVT transmission fluid. Link to comment Share on other sites More sharing options...
dgoodhue Posted February 27, 2021 Share Posted February 27, 2021 Do the tires have different tire depths? (ie have you replace 1 or 2 of the tires) Link to comment Share on other sites More sharing options...
ammcinnis Posted February 27, 2021 Share Posted February 27, 2021 ... just searching on google. You might have better luck looking in the 2015 Owners Manual; the index points to page 3-16: AT OIL TEMP warning light (CVT models) If this light illuminates when the engine is running, it may indicate that the transmission fluid temperature is too hot. If the light illuminates while driving, immediately stop the vehicle in a safe place and let the engine idle until the warning light turns off. Transmission control system warning If the “AT OIL TEMP” warning light flashes after the engine has started, it may indicate that the transmission control system is not working properly. Contact your nearest SUBARU dealer for service immediately. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
denokarter Posted February 28, 2021 Author Share Posted February 28, 2021 Do the tires have different tire depths? (ie have you replace 1 or 2 of the tires) No I haven’t touched the tires Link to comment Share on other sites More sharing options...
denokarter Posted February 28, 2021 Author Share Posted February 28, 2021 You might have better luck looking in the 2015 Owners Manual; the index points to page 3-16: Freezing cold in Canada, surprised that it would get hot in this weather after 5 min of driving. Something strange Thank you Link to comment Share on other sites More sharing options...
Elxiddic Posted March 19, 2021 Share Posted March 19, 2021 Did your problem end up getting fixed? Envoyé de mon LG-M703 en utilisant Tapatalk Link to comment Share on other sites More sharing options...
denokarter Posted April 30, 2021 Author Share Posted April 30, 2021 Did your problem end up getting fixed? Envoyé de mon LG-M703 en utilisant Tapatalk Yes, the dealership replaced the Transmission Control Module, covered under warranty. Now, i dont know if they did a transmission flush as well, so i might do that soon. Link to comment Share on other sites More sharing options...
