Js_Subi Posted September 7, 2016 Share Posted September 7, 2016 Hi there guy! I'm new to Subaru turbo games. I recently purchased a 05 legacy gt. After a couple of days I started having slow turbo spooling and strong gas smell. Buddy told me I may have a boost leak. So I checked all the lines at tighten them and zip tied them if needed. So has anyone had this problem or can help me with this? I think it might be the up pipe gasket that may be leaking. Reason is the gas smell comes from that location. In the morning the car drives normal but as the day goes by the leak starts happening again. It also has a 3in down pipe. Car is stage 2 pro tune. The up pipe is stock. If you guys can help I would greatly appreciate it!! Link to comment Share on other sites More sharing options...
Charbo Posted September 7, 2016 Share Posted September 7, 2016 I would not run a stage 2 tune on a stock catted uppipe..I'm not sure if that would make it smell like gas but I'm sure most people will say the same. Link to comment Share on other sites More sharing options...
Tuning Alliance Posted September 7, 2016 Share Posted September 7, 2016 Check what you think first !! Also did you do a boost leak test? Or just tighten up what you could see? Really need to do a proper test. -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Charbo Posted September 8, 2016 Share Posted September 8, 2016 Check what you think first !! Also did you do a boost leak test? Or just tighten up what you could see? Really need to do a proper test. -Brian Couldn't the catalytic convertor collect some gas, causing the smell? Especially if there is a leak in the gasket or connection making it smell worse than if it went all the way through the exhaust? Link to comment Share on other sites More sharing options...
Js_Subi Posted September 8, 2016 Author Share Posted September 8, 2016 Thanks guys for your help guys... I'm getting headers and up pipe soon.. But for now I think I'm going to replace the gasket and see what sup.. Link to comment Share on other sites More sharing options...
Phate Posted September 8, 2016 Share Posted September 8, 2016 Thanks guys for your help guys... I'm getting headers and up pipe soon.. But for now I think I'm going to replace the gasket and see what sup.. It doesn't really need headers. Just get a catless up pipe, either an OEM one from something newer than 2006, or a shiny aftermarket one. Link to comment Share on other sites More sharing options...
Js_Subi Posted September 9, 2016 Author Share Posted September 9, 2016 Thank @phate I'll keep that in mind.. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 9, 2016 Share Posted September 9, 2016 Right you don't need headers. Put that money somewhere else. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Js_Subi Posted September 9, 2016 Author Share Posted September 9, 2016 Yea I check my oil every day.. I have. A small oil leak in the back on a hose... Thanks again on the heads up @max Link to comment Share on other sites More sharing options...
Js_Subi Posted September 11, 2016 Author Share Posted September 11, 2016 Hey guys I'm getting a sti acted up pipe from somebody in my town... Is it necessary to retune again or can I drive it like that.. I was looking at mine after I took it off and it dose not have anything inside the tube... Just ceramic all the way out.. If that a cat less up pipe? Link to comment Share on other sites More sharing options...
Phate Posted September 11, 2016 Share Posted September 11, 2016 Catless up pipe on the left, catted on the right, looking down the turbo flange: http://i486.photobucket.com/albums/rr221/Gcxrs05/STI%20Exhaust%20Manifold%20and%20up-pipe/IMG_4165.jpg You shouldn't need to make any tuning changes with a catless up pipe vs catted. I'm still running the cobb off the shelf stage 2 maps with a turboXS catless up pipe and Invidia catted downpipe. Link to comment Share on other sites More sharing options...
Js_Subi Posted September 11, 2016 Author Share Posted September 11, 2016 Nice I have a castles up pipe already on it.. With no egt instal Link to comment Share on other sites More sharing options...
