Spec.Battle Posted October 8, 2014 Share Posted October 8, 2014 My clutch is going out and was told the Exedy OEM clutch kit and OEM flywheel was the way to go?! Any suggestions or experience is very helpful. The shop wants to order direct from Subaru, but I may go this route instead. Thank you Link to comment Share on other sites More sharing options...
Spec.Battle Posted October 8, 2014 Author Share Posted October 8, 2014 2006 Spec.B is what I have Link to comment Share on other sites More sharing options...
Max Capacity Posted October 8, 2014 Share Posted October 8, 2014 Your FW should be able to be turned and reused. Exedy is a good company. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
spritefiend Posted October 9, 2014 Share Posted October 9, 2014 I have an exedy oem replacement clutch for my 05 lgt, and it chatters A LOT. It's driving me nuts. But, that's the only complaint I have for it.. and that's not half bad. Link to comment Share on other sites More sharing options...
Spec.Battle Posted October 9, 2014 Author Share Posted October 9, 2014 Ok yea we are going to try to resurface the flywheel and if it can't be reused then get a new flywheel. Wasn't sure what route to take with the clutch. Thanks guys Link to comment Share on other sites More sharing options...
mdzowner Posted October 9, 2014 Share Posted October 9, 2014 thats the setup i used when i replaced my clutch get a tbsk kit while your in there Link to comment Share on other sites More sharing options...
Spec.Battle Posted October 10, 2014 Author Share Posted October 10, 2014 thats the setup i used when i replaced my clutch get a tbsk kit while your in there Is it a tool kit? I'm having a shop install the clutch for me. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 10, 2014 Share Posted October 10, 2014 Correction, I just noticed you have a 06 Spec B, 5mt. you may have a DMFW. Contact Mike at www.AZPinstalls.com tell him what you have, he will get the correct clutch for you. And SMFW if you need. I'm being to rethink the TSK3 kit. If you do the right prep work for the TOB and tranny snout you should be fine if your not having any issues. IMO, I'm not a big fan of OEM style clutches in cars. I'd alway's set up. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Spec.Battle Posted October 11, 2014 Author Share Posted October 11, 2014 Correction, I just noticed you have a 06 Spec B, 5mt. you may have a DMFW. Contact Mike at www.AZPinstalls.com tell him what you have, he will get the correct clutch for you. And SMFW if you need. I'm being to rethink the TSK3 kit. If you do the right prep work for the TOB and tranny snout you should be fine if your not having any issues. IMO, I'm not a big fan of OEM style clutches in cars. I'd alway's set up. Thank you. I'll contact them. I want something good and nothing too crazy as my car is almost stock. But if I'm doing it I wanna don't right and good. Thank you Link to comment Share on other sites More sharing options...
