badtiming Posted September 28, 2014 Share Posted September 28, 2014 When I pulled into my driveway last night I noticed my light flickering against the door. I just installed LEDs so figured maybe it was due to that but when I got out I noticed my drivers side fog light was almost half way filled with water! Is this common? And how would you guys suggest getting it out? My only solution seems to be to take out the whole fog light assembly and dump it out. Link to comment Share on other sites More sharing options...
turboboost Posted October 1, 2014 Share Posted October 1, 2014 It's pretty common. Check to make sure that the bulb is seated and "locked in" correctly. Easy solution is to just take off the front bumper, remove the bulb, and stand it upright so that the water drains out of the fog assembly. Let it air-dry for a few hours on a hot day and you're golden. Link to comment Share on other sites More sharing options...
badtiming Posted October 1, 2014 Author Share Posted October 1, 2014 Thanks for the reply, I thought I deleted this thread. I ended up just taking the whole thing out and doing exactly what you described. Thanks though!! Link to comment Share on other sites More sharing options...
turboboost Posted October 1, 2014 Share Posted October 1, 2014 Ha, no problem. Glad it worked out. Link to comment Share on other sites More sharing options...
spritefiend Posted October 2, 2014 Share Posted October 2, 2014 too much blinker fluid. Link to comment Share on other sites More sharing options...
