FP and Injector question
Replacing my FP and injectors nearly 200K on both, priced out OEM replacement vs AEM 340 + ID1050x its not that much difference in price (New OEM Injectors not reman).
Currently running Stage 2 custom tune 19psi,
Any snags with using the AEM in stock housing? 1050x might be overkill but I'll be replacing the 46 with a 52, so I figured might as well get that out the way.
Or should I go with a different FP + Inj combo?
Those 1050x's will flow more than enough for a vf52 on E85. Great combo IMO
The pump is direct drop in, i believe it even includes 2 O-rings, same pump I have in my car now, make sure you buy the lower half of the fuel pump assy (fuel filter)
Good luck!
I thought the AEM320 is the pump.
Will the AEM 340 fit, I don't really know.
Here's what my wagon has, recommended by my Tuner.
Engine Build - Click Here
Good luck!
Yeah your 46 is still solid as a rock :lol: like I wish it would develop play, had the DP off for coating couple weeks ago, check play, there was none.
