JohnnyWas Posted August 2, 2018 Share Posted August 2, 2018 thanks johnny for taking the time to write this up. so does the DRL come on during the day? when i tested mine, the DRL came on with the headlights and i gave up, was too tired to resolve. I had disabled my DRLs with my old headlights so I didnt bother to wire up for them this time around. Link to comment Share on other sites More sharing options...
05MNLGT Posted August 3, 2018 Author Share Posted August 3, 2018 going to talk with Arnold about how he wired up his drls. i'd like everything to work as designed. in the meantime i bought these puppies. the can brackets are finally done. everything takes longer when it's free. Link to comment Share on other sites More sharing options...
05MNLGT Posted August 4, 2018 Author Share Posted August 4, 2018 here is the jdm blues on my car now. i may not sell them. so beautiful. Link to comment Share on other sites More sharing options...
05MNLGT Posted October 3, 2018 Author Share Posted October 3, 2018 other projects done so i'm back to this. looking at the jdm harness for the wiper washers and trying to figure out how to add the washer motor for the lamps. Front wiper washer motor wiring: BW (12G) YB (10G) wiring for the front wiper washer motor looks to be the same for both USDM and JDM. Lamp washer Single BW (10G) wire. not sure where it comes from Relay: Y (10G) connecting to lamp washer motor Lamp washer motor is 12V Koito 11958 Relay wires Y (10G) YB (10G) B (10G) BW (12) Br (12) BL (10G) Link to comment Share on other sites More sharing options...
05MNLGT Posted October 3, 2018 Author Share Posted October 3, 2018 i wondering if i cut the BW and Y 10G wires from the JDM harness and splice them into the USDM harness with the YB and BW that connects to the front wiper washer? that way when i press the wiper washer, it will activate the lamp washers. Link to comment Share on other sites More sharing options...
05MNLGT Posted October 3, 2018 Author Share Posted October 3, 2018 screw it. my friend's shop is going to do it for me. i just don't have the time. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 18, 2018 Share Posted October 18, 2018 Threadjacking a little and bumping this thread UTC_pyro, what do you think of the following method to switch the JDM light beam pattern closer to the USDM one? Here's an update on swapping the projectors/shields in the facelift JDM lights: it's really easy. How much difference it actually makes idk cuz I never mounted them in the car before swapping projectors, but the light pattern looks fine. I do need to adjust the angle a little tho because the passenger's side light is aimed too low, and the driver's side is about right. Sent from my iPhone using Tapatalk It really is that intuitive. Pull apart both headlights, take out the four little screws that hold each shield/projector assembly in place, and put the driver's side assembly in the passenger's light and vice versa. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
utc_pyro Posted October 18, 2018 Share Posted October 18, 2018 I'm not sure what fotofan was trying to achieve there, the shield and projector are identical between the drivers and passengers side. So that really did nothing. You really have four options: Flip the JDM shield - This causes things to be out of focus Use the USDM halogen shield. You loose some width and again focus isnt perfect.Make a custom curved shield out of a coke can or the like. If you have the skill this is the best performing option. It's an option that requires a lot of sub mm cutting and bending skill, patience, and in-depth understanding of optical physics. I have the laster, but not the former two.Use the adapters I designed and drop in an off the shelf aftermarket projector. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 18, 2018 Share Posted October 18, 2018 Thanks for your input. I am a bit confused now. If the shields are the same, then how do you get different light cut out between the driver and passenger sides? Link to comment Share on other sites More sharing options...
rhino6303 Posted October 19, 2018 Share Posted October 19, 2018 Thanks for your input. I am a bit confused now. If the shields are the same, then how do you get different light cut out between the driver and passenger sides?Both JDM shields have the shape of --\_ while USDM shields have the shape _/--. Therefore you must flip the JDM shields 180° and remove a metal tab for the USDM light pattern. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 19, 2018 Share Posted October 19, 2018 So to be clear, they both have these shapes but are not exactly identical, are they? If yes, then what makes the driver side headlight beam pattern on the JDM point higher than the passenger side? Also, it just came to me... I know it is not ideal but couldn't I just hook up the leveling motor on the driver side only and make it point lower. Then, unplug the driver side and connect the passenger side leveling motor to get that light to point a bit higher? Trying to look at all (easy) options Also putting this here for reference even though it is for pre facelift. https://legacygt.com/forums/showthread.php/jdm-hid-headlight-conversion-walkthrough-113094.html Link to comment Share on other sites More sharing options...
rhino6303 Posted October 19, 2018 Share Posted October 19, 2018 So to be clear, they both have these shapes but are not exactly identical, are they? If yes, then what makes the driver side headlight beam pattern on the JDM point higher than the passenger side? Also, it just came to me... I know it is not ideal but couldn't I just hook up the leveling motor on the driver side only and make it point lower. Then, unplug the driver side and connect the passenger side leveling motor to get that light to point a bit higher? Trying to look at all (easy) options Also putting this here for reference even though it is for pre facelift. https://legacygt.com/forums/showthread.php/jdm-hid-headlight-conversion-walkthrough-113094.htmlIf you have one light that is higher than the other, your lights need to be adjusted or your eyes could be playing a trick and making one side appear higher than the other. If you put your lights 25' from a wall when you are on a level surface you should be able to mark the beam pattern with tape and adjust. The shields are 100% identical for both sides. That is, USDM would have 1 part number for both and JDM would have 1 part number for both (if you could purchase just the shields but, alas you cannot). Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 19, 2018 Share Posted October 19, 2018 If you have one light that is higher than the other, your lights need to be adjusted or your eyes could be playing a trick and making one side appear higher than the other. I guess what I am getting at is adjusting the jdm lights 'up and down' without opening them up and touching the shields and stuff. As far as I understand, as they sit, the driver side will blind the oncoming traffic while the passenger side is currently pointing too low for us usdm drivers. That's why I was thinking to adjust each one of them separately, up and down using their respective leveling motor, until I set them so I don't blind the oncoming traffic. Of course, I am not sure what kind of overall pattern I am going to get. And it could be that the passenger side may blind oncoming traffic once I point it a bit higher. I don't know. Link to comment Share on other sites More sharing options...
utc_pyro Posted October 19, 2018 Share Posted October 19, 2018 The JDM lights use a really soft sealiant, you don’t even need to bake them to open them. There is no reason to be afraid of prying them open to adjust something, you can do it in less than an hour. Adjusting them how you propose really won’t work because they project much wider than your car. Thus your passenger side light will still blind oncoming cars. Edit: speaking of this, I need to go take mine apart and see why the passenger side light stopped working in the last week... Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 19, 2018 Share Posted October 19, 2018 OK. I'll give it a go then. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 27, 2018 Share Posted October 27, 2018 (edited) Well, I finally tackled this job. I think it went OK overall. Did not use any washer or stuff like that. Followed the advise from the other walk-through thread, which mentioned to carefully flaten the concave area of the shield. Came out at least better than the original JDM pattern IMHO. A bit of blue color on the upper edge but who cares . At least, it is sharper and I won't blind oncoming traffic. Freakin can't wait to install the front end! Adding this for reference (LHD vs RHD OEM shields): http://foto.slovenija.net/photos/Danci/Razno/Subieforum/Zarometi/20131017_193842-7.jpg Edited December 14, 2018 by xt2005bonbon Link to comment Share on other sites More sharing options...
ehsnils Posted October 28, 2018 Share Posted October 28, 2018 Well, I finally tackled this job. I think it went OK overall. Did not use any washer or stuff like that. Followed the advise from the other walk-through thread, which mentioned to carefully flaten the concave area of the shield. Came out at least better than the original JDM pattern IMHO. A bit of blue color on the upper edge but who cares . At least, it is sharper and I won't blind oncoming traffic. Freakin can't wait to install the front end! The blue tint is normal and you see that on almost every car with a HID light, even OEM. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 28, 2018 Share Posted October 28, 2018 The blue tint is normal and you see that on almost every car with a HID light, even OEM. Then I did a good job . I never had a car with hid before actually. So I wouldn't know. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 29, 2018 Share Posted October 29, 2018 Per your question via PM: "IGG+" is just a generic term for the electrical bus that comes on the the ignition set to "ON". I got it from the OP connector and built a logic circuit that made it work the same as the OEM DRL module works (Generator signal to on & parking break off = enabled). If you don't want to go to that level of hassle, just using the +V off the 3-pin headlight connector should also work. utc_pyro, I would like to use my 'corner lights' (the ones between the blinker and low beam on the jdm) as DRL. I would like to make it as simple as possible in terms of wiring. Now I may have missed it in the thread, but how do I exactly go about doing that and making sure that the low beam hid are effectively disconnected from the DRL module? Link to comment Share on other sites More sharing options...
05MNLGT Posted November 1, 2018 Author Share Posted November 1, 2018 going to give this a try next week. direct plug-n-play with usdm harness and replaces the jdm harness on the lamps. Link to comment Share on other sites More sharing options...
05MNLGT Posted November 1, 2018 Author Share Posted November 1, 2018 coming next week. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 12, 2018 Share Posted November 12, 2018 I successfully wired my hid low beams as well as high beams and corner lights and everything. I would like to avoid having the hid turn on before the engine cranks. I cannot expect my wife to switch off the hid low beams before the engine cranks . Is there a wire in the engine bay that I can tap to and use with a relay to achieve what I'm describing? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 16, 2018 Share Posted November 16, 2018 Can someone clarify this for me. I have a set of USDM facelift headlights that have been separated already. Can I separate the JDM Facelift headlights and swap the metal shields. Basically putting the USDM shields into the JDM headlights, should that fix the issue of blinding oncoming traffic? You could do what I did. I posted some pics in a previous post on this thread, where I flipped the jdm shield and carefully flattened it. The pattern is almost perfect now and much sharper than stock jdm. Link to comment Share on other sites More sharing options...
ehsnils Posted November 16, 2018 Share Posted November 16, 2018 I successfully wired my hid low beams as well as high beams and corner lights and everything. I would like to avoid having the hid turn on before the engine cranks. I cannot expect my wife to switch off the hid low beams before the engine cranks . Is there a wire in the engine bay that I can tap to and use with a relay to achieve what I'm describing? You might be able pull something from the alternator. Like a relay driven from the yellow marked and then to ground. You got to try to see if it behaves like you expect. http://www.bedug.com/pics/Subaru/alternator.png But have an override switch in place as well to take care of if the alternator fails. I have also seen oil pressure switch operated solutions. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 16, 2018 Share Posted November 16, 2018 Thanks eshnils for the suggestion. I have had a look at the FSM and these kind of diagrams but was unsuccessful at finding a solution. Almost all wires have 'ACC' or 'IG' supplied current. I will look into your suggestion and do some checking using a voltmeter. If all else fails, then I'll install a timer like this one with a relay. Link to comment Share on other sites More sharing options...
