choover1101 Posted August 6, 2016 Share Posted August 6, 2016 I have a 96 Legacy Gt 224k miles. At highway speeds (70ish) if i let off the throttle the passenger side dips down. if I press on the throttle it raises back up. Slight steering wheel turn to the right accompanies this. I realize this isn't torque steer but that is the closest thing i have felt to this but in reverse. Of course i don't notice this until i have a 4.5 hr drive planned tomorrow. If anyone has any thoughts or ideas it would be appreciated. Symptoms 70ish mph No throttle passenger side sag and wheel turns to passsenger side Throttle everything returns to normal Link to comment Share on other sites More sharing options...
choover1101 Posted August 7, 2016 Author Share Posted August 7, 2016 For anyone who may have this issue in the future. My ABS was sending pressure to that one caliper under driving conditions. I removed both ABS relays behind the headlight and went about my trip. I plan on an abs delete when i do the 04 brake upgrade so factory functionality is not critical for this. Link to comment Share on other sites More sharing options...
wtdash Posted August 9, 2016 Share Posted August 9, 2016 Good catch. How did you diagnose the ABS? That would've not been on my list. TD Link to comment Share on other sites More sharing options...
choover1101 Posted August 10, 2016 Author Share Posted August 10, 2016 I bought the car 3 weeks ago with a broken caliper bracket bolt on that side. I have an abs light (removed the bulb) and had cleaned a ton of crap off of the sensor on that wheel. I haven't had all the wheels off so that one must have been sending a moving signal while the others were "stopped". also it felt almost like a brake drag. With the impending drive I was willing to try odd stuff. Summary known brake issues known clean sender on that wheel ABS light feelings Link to comment Share on other sites More sharing options...
