PassedTents Posted May 22, 2020 Share Posted May 22, 2020 (edited) I have two Retro-Quik kits from The Retrofit Source for sale. Its projectors and adapters only for both kits, but I have some other bits as well. Prices don't include shipping. I can wipe things down with a clorox wipe or whatever if you feel more comfortable. I'm near UW campus, so I can do local handoff in this area. 1: Was in and out of the headlight housing a few times, and shows a bit of wear on the projector body and the adapter plates. The lenses are good. I tested the solenoids, and they're good too. This set has the upgraded bulb holders installed. I managed to lose both an original screw and an extended screw, so there are only 11 total of each. Sealant included: SOLD 2: Effectively new in box, I think I had the adapters out once to compare to the other set I had. Never mounted. Sealant included: SOLD Sealant: GONE I have 9006 splitters, so you can power the solenoids in the projectors, if you want: SOLD I also have a set of 55w, 5500k h1 HID bulbs, ballasts and a dual relay wiring harness from DDM: SOLD Bulbs available ^: $10 90mm Switchback LED halos. They were mounted up once, but don't appear to have any wear: SOLD Amber corner lights, in case you want to go clear corners, but the lights need to be yellow *shrug*: SOLD Gas struts I snagged off RockAuto that I never installed: $10 GrimmSpeed Master Cylinder Brace ('05-'07 GT, non-vdc): SOLD Edited May 28, 2020 by PassedTents Link to comment Share on other sites More sharing options...
sd2180 Posted May 22, 2020 Share Posted May 22, 2020 Pm sent for brace Link to comment Share on other sites More sharing options...
limberpineobxt Posted May 22, 2020 Share Posted May 22, 2020 Are the gas struts for the rear wagon hatch? Link to comment Share on other sites More sharing options...
PassedTents Posted May 22, 2020 Author Share Posted May 22, 2020 Are the gas struts for the rear wagon hatch? They were the recommendation I found on this site at the time I bought them. It appears there's a better choice now: https://legacygt.com/forums/showpost.php?p=5864460&postcount=28 These will work, but it sounds like there's a bit of adjustment to make them fit. Link to comment Share on other sites More sharing options...
moddingbug Posted May 26, 2020 Share Posted May 26, 2020 PM Sent on the 2nd set of Retroquik projectors & adapters. Link to comment Share on other sites More sharing options...
