Jags Posted January 26, 2022 Share Posted January 26, 2022 Hello all, This is something that I've been wondering, from reading all the posts it seems like the front diff is supposed to have 75W-90 gear oil in it. My legacy on the other hand seems to have ATF in it's front diff, now I had the vehicle given to me by my brother n law so not exactly sure if it was replaced by him or not but he didn't drive it much. It drives perfectly fine with no issues, no noises other than lower control arms knocking, shifting fine etc. Should this be any concern? Link to comment Share on other sites More sharing options...
Berge56 Posted January 26, 2022 Share Posted January 26, 2022 Change the fluid with fresh 75-90 gear oil and see if the ATF tint comes back. If it does you could have a leak inside the transmission. Link to comment Share on other sites More sharing options...
Jags Posted January 26, 2022 Author Share Posted January 26, 2022 (edited) Well, I went ahead and checked it again, smells like gear oil but has a tint of red. Could just be me though, still probably wouldn't hurt to change it out in the future. Though if it were to be leaking inside the trans is this something I should be concerned about or no? Edited January 26, 2022 by Jags Link to comment Share on other sites More sharing options...
xavdefr Posted January 26, 2022 Share Posted January 26, 2022 The ATF fluid is for automatic gearbox The 75w90 oil is for manual gearbox, front diff (automatic) and rear diff Link to comment Share on other sites More sharing options...
Max Capacity Posted January 26, 2022 Share Posted January 26, 2022 Is Redline 75w-90 red in color ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
All_talk Posted January 26, 2022 Share Posted January 26, 2022 Like Berge said, check the level of the AT section. You could have a leak that is passing ATF form the trans into the diff section of the transaxle. Link to comment Share on other sites More sharing options...
apexi Posted January 27, 2022 Share Posted January 27, 2022 Is Redline 75w-90 red in color ? I have some leftover 75w-90ns that's around 5 years old, it's amber. Not sure about other varities Link to comment Share on other sites More sharing options...
