Brighton96 Posted October 11, 2016 Share Posted October 11, 2016 So I have been thinking of doing autocross next year, mostly just for fun since there are a lot of timed events like that locally but I literally know nothing. So I've got a few questions and could use some advice So first question: Whats the stock sizes for 2nd gen sway bars? I currently have 19mm front and 18 mm back with polyurethane bushings and stock end links Was it an extra option to have the brace running under the back seat of our cars? I've only seen a few cars with them but I don't know if I should still do strut braces or if that brace would be a good substitute. Just so you know what brace I'm talking about And then any suggestion on tires? I've got 4th gen 5 spoke 17x7 wheels and was thinking of getting some sticky road tires, maybe Potenza S001 or RE760 I won't be doing coilovers since I live in the mountains so ride height is going to stay the same for now Link to comment Share on other sites More sharing options...
thedeadhp Posted October 12, 2016 Share Posted October 12, 2016 Wow I didn't even know there was a reinforcement bar there! I would still get a rear strut bar, I'm not sure which ones will fit but I would assume they aren't too expensive. that would really help considering you are on stock struts etc. If you did coils you could set the ride height up high and set the preload of the springs as to still stiffen the car up! And I think outbacks came with a rear 18mm and a front 19mm. But normal legacy's like yours came with smaller stock, I believe. Link to comment Share on other sites More sharing options...
wtdash Posted October 13, 2016 Share Posted October 13, 2016 REad up on your AutoX rules...suspension and wheel/tire mods may change your classification...if if matters. Some just do it for fun - not points - so they don't care. Link to comment Share on other sites More sharing options...
