Jimblaz Posted December 8, 2010 Share Posted December 8, 2010 So i just got my new hella supertones and cant seem to wire them up correctly. i have the Subimods relay. I plugged into the innermost horn with the male part. Then i just put on the relay. ground the 2 grounds and plug in the horns. i push on the wheel and nothing. I hear a little click like it wants to work but no luck. any help?? Link to comment Share on other sites More sharing options...
legacyduane Posted December 8, 2010 Share Posted December 8, 2010 There arent two grounds. One goes to the battery Link to comment Share on other sites More sharing options...
Jimblaz Posted December 8, 2010 Author Share Posted December 8, 2010 whoops. that would explain it. hahaha Link to comment Share on other sites More sharing options...
legacyduane Posted December 9, 2010 Share Posted December 9, 2010 You get them working? Link to comment Share on other sites More sharing options...
Jimblaz Posted December 9, 2010 Author Share Posted December 9, 2010 I did. and let me tell you.... these suckers are LOUD!!!!. i like it. Link to comment Share on other sites More sharing options...
BAC5.2 Posted December 9, 2010 Share Posted December 9, 2010 Pfft 2. That's nothin. I have 6. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Jimblaz Posted December 10, 2010 Author Share Posted December 10, 2010 6?!?!?!?! you trying to make those poor people in front of you deaf??? hahahah Link to comment Share on other sites More sharing options...
W1CKED Posted December 13, 2010 Share Posted December 13, 2010 So i just got my new hella supertones and cant seem to wire them up correctly. i have the Subimods relay. I plugged into the innermost horn with the male part. Then i just put on the relay. ground the 2 grounds and plug in the horns. i push on the wheel and nothing. I hear a little click like it wants to work but no luck. any help?? Did you take yer front bumper off to install them? Link to comment Share on other sites More sharing options...
Jimblaz Posted December 13, 2010 Author Share Posted December 13, 2010 nope just took out the airbox. Its pretty easy if your leaving the stock horns in there. Just unplug em and plug in your harness. :-) nice and easy Link to comment Share on other sites More sharing options...
W1CKED Posted December 14, 2010 Share Posted December 14, 2010 nope just took out the airbox. Its pretty easy if your leaving the stock horns in there. Just unplug em and plug in your harness. :-) nice and easy Sweeeeeeet...thanks for the head's up. Link to comment Share on other sites More sharing options...
09_Red_GT Posted December 22, 2010 Share Posted December 22, 2010 Do all installs need the harness/relay? Did you get the bracket from subimods as well, was it worth it? habitual derail-er Link to comment Share on other sites More sharing options...
Jimblaz Posted December 22, 2010 Author Share Posted December 22, 2010 i used the bracket and the relay. on black friday the bracket was free with the horns. I like it. Puts the horns right up there. The relay worked pretty well with the harness but isnt needed. You can easily make your own harness. Link to comment Share on other sites More sharing options...
joeblow Posted December 29, 2010 Share Posted December 29, 2010 Harness isn't necessary if you have any kind of electrical experience. I just did mine yesterday and didn't have any trouble. I just followed the install chart that I found here on a search. Just get a bunch of these to fit onto the posts of the relay and the horns and some wire and you're good to go. http://www.2carpros.com/images/articles/electrical/connector/wire_connectors.jpg It's cool; I'm with the band Link to comment Share on other sites More sharing options...
joedirtae09 Posted January 4, 2011 Share Posted January 4, 2011 i didnt use a relay and theyve been working fine.... are there any drawbacks for not using a relay? Link to comment Share on other sites More sharing options...
BAC5.2 Posted January 4, 2011 Share Posted January 4, 2011 I used a relay because I wanted the horns to be able to draw as much current as they can. They are plenty loud. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
lltomtomll Posted January 4, 2011 Share Posted January 4, 2011 The relay doesn't amplify the horns. The stock horns run through the same 12v current like the hella tones. I have heard other with hellas horn with the relay and they sound just as loud as mine. Link to comment Share on other sites More sharing options...
BAC5.2 Posted January 4, 2011 Share Posted January 4, 2011 The relay doesn't amplify the horns. The stock horns run through the same 12v current like the hella tones. I have heard other with hellas horn with the relay and they sound just as loud as mine. Incorrect. Voltage and current are very different things. Thin wire has higher resistance when trying to flow high current. 18 gauge wire has 4 times the resistance of 12 gauge wire. Higher current means louder horns. Through wire, higher current means higher temperatures, and resistance is the enemy. My horn wiring runs cooler, and is more efficient, than using the stock wiring. Plus, if something were to go wrong, the horn circuit is completely independent of the cars circuit (save a single wire, used to trigger the relay). A while back, I back-fed checked the voltage and current drop for the headlight harness on my old Forester. The difference between the aftermarket harness I built and the stock wiring was substantial. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
lltomtomll Posted January 4, 2011 Share Posted January 4, 2011 OoooOo. Interesting. Link to comment Share on other sites More sharing options...
