citka Posted March 8, 2011 Share Posted March 8, 2011 Besides Whiteline, is anyone aware of a set of adjustable control arms for the back of the Gen 4 Legacy wagons/sedans? Link to comment Share on other sites More sharing options...
suds2250 Posted March 10, 2011 Share Posted March 10, 2011 perrin made a set but they are out of production. 335HP/360Tq VF-22/1820 clone with Meth Link to comment Share on other sites More sharing options...
turbodog Posted March 10, 2011 Share Posted March 10, 2011 Are there any bushing upgrade options for the rear arms? For the spec.b? Bushings from the '08+ wrx/sti? Aside from the whiteline rear camber kit? I've looked a bit but had no luck. Link to comment Share on other sites More sharing options...
BAC5.2 Posted March 10, 2011 Share Posted March 10, 2011 If you want to pull camber out of the back (or put some in), just run the Whiteline KCA-399. I currently run -2º in the rear, but I'll push that back out the next time I feel like doing an alignment. I'll probably run -1.1º in the rear. I run about -0.9º in the front IIRC. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
2point5_GT Posted October 14, 2013 Share Posted October 14, 2013 I'm super late on this but I'm looking to increase negative camber a few degrees. Would the whiteline adjustable rear lower control arms do the trick? Thanks! Link to comment Share on other sites More sharing options...
boxkita Posted October 18, 2013 Share Posted October 18, 2013 I'm super late on this but I'm looking to increase negative camber a few degrees. Would the whiteline adjustable rear lower control arms do the trick? Thanks! yes. A few degrees? You're going to have tire clearance issues at a few degrees, tho. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
FPerron Posted October 18, 2013 Share Posted October 18, 2013 4boxparts Link to comment Share on other sites More sharing options...
