Fasemelta Posted June 22, 2019 Share Posted June 22, 2019 With my a/f trims seeing constant +10's, the time has come for me to replace the aging vacuum lines with a silicone kit I picked up a few years back from Free Range racing. I'll also be replacing the: Turbo inlet IM gaskets Throttle body/ IM gasket Looking for advice on things to look for and replace while I have the manifold off. Link to comment Share on other sites More sharing options...
Chocoholic005 Posted June 22, 2019 Share Posted June 22, 2019 My whole car turned into a while you’re in there hahaha Link to comment Share on other sites More sharing options...
Code Posted June 22, 2019 Share Posted June 22, 2019 With my a/f trims seeing constant +10's, the time has come for me to replace the aging vacuum lines with a silicone kit I picked up a few years back from Free Range racing. I'll also be replacing the: Turbo inlet IM gaskets Throttle body/ IM gasket Looking for advice on things to look for and replace while I have the manifold off. Are you tuned? Easy time to replace Pcv and check/clean ocv. Delete the TGV and also do the air pump(if your car has one)delete while you’re there. This is also a great time to swap injectors/rails/turbo/bcs/downpipe/fuel pump "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
Fasemelta Posted June 22, 2019 Author Share Posted June 22, 2019 Enabling activated! Haha thanks for the tips Yes 06 5eat wagon Cryotuned with a Jmp custom vf40. Replaced pcv 20k mi ago New ocvs 10k mi ago Professionally cleaned the stock injectors about the same time No airpump Aftermarket up pipe and turbo back. With 130k on the clock I've done a lot of pre-maintence to keep her running well. I'm pretty satisfied with the power levels at the moment and would like to run this motor like this until it blows. Just looking for things that may be leaking (or about to leak) so I can eliminate them while it's easy to reach. The fuel rail crossover in the front looks pretty rusty...not sure how easy that will be to swap Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
JmP6889928 Posted June 23, 2019 Share Posted June 23, 2019 How long after the tune did it start acting up? You may want to re-tune if there were possible failures brewing during your original tune. Link to comment Share on other sites More sharing options...
Fasemelta Posted June 24, 2019 Author Share Posted June 24, 2019 I've been on the tune for a few years now and don't have any issues with the car at the moment. I typically drive with my ap running to monitor and have noticed my a/f trims getting up to the +10's and not coming down below 5. It's taken a year or two to go from the 0-5 range to the current 5-10 I'm seeing. I haven't smoke tested, but assume it's the vacuum lines slowly leaking. I will definitely consider a re tune after I get everything swapped to silicone and with a new turbo inlet. Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
