WESTcoast Posted November 24, 2010 Share Posted November 24, 2010 I have a 99 lgt sedan and I have a set of STI control arms, the difference is that its forged and alumminum so stronger and lighter. My control arm is done, because of i hit a curb. Will these fit in my lgt? They came off a wrx so im sorta confident but i do know that the wrx has a wider track than the GC so i not all too sure about that. Any one have any suggestions?!?! Link to comment Share on other sites More sharing options...
WESTcoast Posted November 24, 2010 Author Share Posted November 24, 2010 bump anyone?? Link to comment Share on other sites More sharing options...
subikid90 Posted November 25, 2010 Share Posted November 25, 2010 Dang I just had mine out of my car the other day, I could have taken measurements. If the shape is similar then I would just measure the mounting hole distances and see if it would bolt up. Or maybe some smart person will come along lol -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted November 25, 2010 I Donated Share Posted November 25, 2010 If you have the new one already, try and bolt it in. They are not that hard to do. The shot control arm has to come out anyways. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
WESTcoast Posted December 1, 2010 Author Share Posted December 1, 2010 Yeah here were my findings: WRX and STi (acually any turbo subaru) control arms will not work for our cars here is why -They use a 60mm front bushing on the control arms and we use a 55mm bushing. -WRX's have a wider track than our legacys which means that your wheel will be pushed out more but if you try to hook up your stock axles and outer tie rod, you will be faced with having around -1 negative camber natually ethier that or it wont work, i wouldnt try it The good news is that you can get jdm impreza control arms they are the same as ours except they are forged and aluminum so thier stronger and lighter! They will also bolt right in as they have that 55mm front bushing. Link to comment Share on other sites More sharing options...
