Ares3985 Posted September 6, 2019 Share Posted September 6, 2019 Anyone know if you can tighten the small arm that the actuator connects to? I have a small leak coming from it and not sure what the fix would be? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
JmP6889928 Posted September 6, 2019 Share Posted September 6, 2019 You can bend it very slightly but it's very difficult to bend. My guess is your flapper bushing has moved and is allowing the wastegate to leak. Link to comment Share on other sites More sharing options...
Ares3985 Posted September 7, 2019 Author Share Posted September 7, 2019 You can bend it very slightly but it's very difficult to bend. My guess is your flapper bushing has moved and is allowing the wastegate to leak. Just wanna make sure we are talking about the same thing. This is where my leak is. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
ehsnils Posted September 7, 2019 Share Posted September 7, 2019 Looks like a wear issue that is just because the turbo is getting old. I would plan for a replacement since if you have wear there then it may be on its last legs. Link to comment Share on other sites More sharing options...
Ares3985 Posted September 7, 2019 Author Share Posted September 7, 2019 Looks like a wear issue that is just because the turbo is getting old. I would plan for a replacement since if you have wear there then it may be on its last legs. Hmmm not great news. Just got it. The shaft has absolutely no play and the wastegate seats nicely and opens smooth as butter. It doesn’t really seem too worn other than that one area. I just don’t see any way of remedying it. Unfortunately it is a moving part so I can’t even plug it w anything. Well. I guess I’ll run w it as is Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
ehsnils Posted September 8, 2019 Share Posted September 8, 2019 Was it a re-built turbo core you got then? In that case the rebuilder may have considered that it's good enough. The amount of leak you'd get there would be minor. Link to comment Share on other sites More sharing options...
Ares3985 Posted September 8, 2019 Author Share Posted September 8, 2019 Was it a re-built turbo core you got then? In that case the rebuilder may have considered that it's good enough. The amount of leak you'd get there would be minor. I don’t think it was rebuilt. Just in good condition. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
