RubyLGT Posted August 13, 2019 Share Posted August 13, 2019 Hello everyone, I seem to have developed an air pocket in my heater core. I have followed the procedure outlined in the owners manual for burping the system but have had no luck. I also tried using a burping funnel with the nose of the car jacked up with no success. Any tips? I can hear it gurgling in the dash when I shut the engine off! Thanks, Ruby Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 13, 2019 Share Posted August 13, 2019 You may be hearing something else: failing hvac actuator. It also sounds like gurgling when the engine is shut off. But you should only hear it for like 5-15sec after engine shut off. See: https://legacygt.com/forums/showthread.php/sound-inside-dash-turn-off-car-190728p5.html Does the coolant gauge move when you are at operating temp? Or does it stay at the usual spot when the engine is warm? Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 13, 2019 Share Posted August 13, 2019 Force feed the heater core by removing the heater hoses from the engine and directly filling the heater core. Be careful not to use too much pressure and flush it gently at the same time. Used to have to do this on older Chryslers because of how the hoses were routed. Fill it to the top and plug the hoses back on and tighten the clamps. Start and run until hot and burp it again. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 13, 2019 Share Posted August 13, 2019 I need to do that too btw, cause I probably have build up in it resulting in subpar performance on the passenger side vent. Link to comment Share on other sites More sharing options...
RubyLGT Posted August 14, 2019 Author Share Posted August 14, 2019 (edited) Thanks for the replies and the link! I will do the actuator maintenance, but I am thinking it is a pocket of air. I have noticed the temp gauge drop at times after the car has come to operating temp. I am not sure why the system wont self burp with the over flow at the proper level. I am hoping this is not an underlying head gasket problem. The engine was rebuilt approx 13k miles ago and I do not have any other signs at this time. I will give the force flush a shot this weekend. If I have the hvac system off, then shut the car down, would I still hear the actuator? Thanks, Ruby Edited August 14, 2019 by RubyLGT Link to comment Share on other sites More sharing options...
moral hazard Posted August 16, 2019 Share Posted August 16, 2019 Try bleeding the coolant, if you're able to bleed out all the air I think you should be ok. If you get a never ending stream of bubbles , maybe the machine shop didn't sort out the heads correctly during he rebuild process. Or maybe the person rebuilding he engine didn't even bother taking heads to be machined? Anyway an easy way to rule out he heater core is to simply bypass it! Link to comment Share on other sites More sharing options...
Max Capacity Posted August 16, 2019 Share Posted August 16, 2019 Have to ask, did you have the heater temp set to high/hot 85F when you started the engine to burp the system ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RubyLGT Posted August 17, 2019 Author Share Posted August 17, 2019 (edited) I hope the shop did... Ive never taken my cars to a mechanic and have always repaired or rebuilt my own equipment. I bought the leggy already rebuilt by a shop in Portland somewhere a little over a year ago before I bought the car. :x I did get receipes for new oem parts like pistons, oil pump, plugs, gaskets, etc.. No oil or coolant mixing anywhere that I can tell, and the bottom of the engine is clean, so that rules out seepage in my mind. Externally anyways. Yes heater high and at 85 No temp fluxuations so far but, still getting the gurgle. I believe I heard the heater door the other day and it did sound different. I dont mean to sound doom and gloom so soon, but I have been eye balling prices on EJ20x engines. Im not sure if I should go that route or just buy a forged and assembled ej255/7 and find some heads to bolt on. I am not looking for max power by any means as the leg is my DD/dad wagon, but a man needs passing power! Im taking the hose to the heater core tonight as JmP outlined Edited August 17, 2019 by RubyLGT Link to comment Share on other sites More sharing options...
RubyLGT Posted August 18, 2019 Author Share Posted August 18, 2019 Confirmed hvac mixer thing! I installed my cubbypod, which is pretty disappointing.... , and noticed that I can hear the gurgle when the white arm is moving. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 18, 2019 Share Posted August 18, 2019 Great. I just changed one of them about a couple months back. was pretty easy to do. I cannot exactly remember but I think there are four of these actuators: 3 on the passenger side and one on the driver side. The latter requires the dash to be removed which sucks. If you want these things to last the longest, don't press the HVAC buttons Link to comment Share on other sites More sharing options...
