LGT Wagon Suspension swapped into Outback XT
Duffman
I was finally able to swap in the used LGT Wagon suspension I bought here. (thanks SubOperator!).
All in all it went very smoothly.
THIS thread got me started.
I used these two threads from here as a guide:
mccory's Tien install walkthrough and hal9e3's Wagon Pinks Install
Thanks to both of them. mccory's had great pics and hal9e3's had great technical specs like torque numbers.
I was able to do it all myself but a second set of hands would really be helpful, especially for re-installing the front struts. They're really heavy and I ended up going a slightly different rout. I installed the bottom two bolts first and then used my floor jack to raise the assembly up and then bolt in the top hats.
A floor jack is your friend for the lower rear bolts. I used mine along with a closed end wrench to get them loose.
http://i4.photobucket.com/albums/y142/ForceFedGTI/Cars/IMG_0155.jpg
The passenger side rear top nuts are nutz to get at. Since I have a cargo mat, I cut some patches in the trip piece to get at them. Can't see the cuts with the mat.
http://i4.photobucket.com/albums/y142/ForceFedGTI/Cars/IMG_0159.jpg
Outback vs LGT rear spring/strut assembly.
http://i4.photobucket.com/albums/y142/ForceFedGTI/Cars/IMG_0153.jpg
Don't forget to change out the rear bump stops! 20501AE00A is the part number for the rear bump stops. Order two
http://i4.photobucket.com/albums/y142/ForceFedGTI/Cars/IMG_0162.jpg
I tried to take before and after pics but I already had the car positioned and the lug nuts loosened by the time I remembered to take before pics. They're at weird angles because they were taken in the garage. :redface:
Before:
http://i4.photobucket.com/albums/y142/ForceFedGTI/Cars/IMG_0148.jpg
After:
http://i4.photobucket.com/albums/y142/ForceFedGTI/Cars/IMG_0182.jpg
Before:
http://i4.photobucket.com/albums/y142/ForceFedGTI/Cars/IMG_0143.jpg
After:
http://i4.photobucket.com/albums/y142/ForceFedGTI/Cars/IMG_0179.jpg
Before:
http://i4.photobucket.com/albums/y142/ForceFedGTI/Cars/IMG_0169.jpg
After:
http://i4.photobucket.com/albums/y142/ForceFedGTI/Cars/IMG_0180.jpg
After:
http://i4.photobucket.com/albums/y142/ForceFedGTI/Cars/IMG_0178.jpg
I haven't driven it a whole lot yet (just a shakedown run around the block) but it is such an improvement over the Outback suspension. It's no after market setup of course but it suits my needs perfectly. Tighten up the handling without being harsh. My wife will be happy that it still feels like a factory setup.
I'll try and get some better after pics later this week.
Edited by Duffman
  • Replies 330
  • Created
  • Last Reply
Top Posters In This Topic
Don't forget to get an alignment done. You'll probably find your rear toe is out of spec and toe'd in. Put about 150lbs in the back over the axle and get it aligned.
When I replaced my OBXT suspension with the BC Racing BR-Type, the rear toe was the only thing that needed attention.
I love the lowered look and even gap around the tires that the LGT suspension gives. What I don't like too much about the BC Racing setup is the reduced travel. I'd say 5" down to 3" and it's noticeable on rough roads and railway crossings.
I just did a trip from Ottawa to Lake Placid and back and I bottomed out at least 10 times. I dread the BANG when it happens too.
Duffman, congrats on completing the install ! It's amazing how much better the OBXT looks with lower suspension. Really like it this way.
Did you jack the rear shock at the ear as we discussed ? The pic with regular jack shows that you most likely did, just wanted to know if this worked for you.
I hope you enjoy the ride ! Glad my Leggy's suspension could help another Subie owner.
2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K
2007 B9 Tribeca Limited DGM - 258K
SOLD - 2005 OB Limited 5 MT Silver - 245K
SOLD - 2010 OB 6 MT Silver - 205K
Yes, i forgot to mention that I'll be getting an alignment done. I hope to get it Wednesday. Why 150lbs in the back?
SubOperator, I did exactly that. I used the scissor jack from the spare tire for that and used the floor jack to break the bolt loose.
Was it hard or did it come off right away then ?
I want to send a link to this thread to one guy who sold the OBXT due to suspension mods "unavailability" :rolleyes: , if you don't mind.
It was pretty easy. The hardest part was getting the bolt out. There is still alot of pressure on it. I used a center punch (forget what size, it fit the bolt end nicely tho) to hammer them out. The suspension still had enough kick to knock the scissor jack over lol.
Be my guest!
This is encouraging.
Any pics comparing the front struts? I have a very little clearance between the tire & spring perch (running 235-55-17 GYTT's).
06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest.
I'll have to read that when i get some more time.
On a brighter note,
Better after pics!
http://i4.photobucket.com/albums/y142/ForceFedGTI/Cars/IMG_0189.jpg
http://i4.photobucket.com/albums/y142/ForceFedGTI/Cars/IMG_0188.jpg
Looks real nice !
I guess it is time for JDM RSB. Used can be found under 100. Another great DIY mod.
It really is huge. And for me, the perfect solution. It rids the car of the wallow ride but retains factory comfort.
I'd even go out on a limb and say it would be worth it to source the parts new. As it is, if you can find them used like I did, it's a bargain. Thanks again SubOperator!
I'm not sure how much lower it can go without doing the full conversion, ie remove all the sub frame spacers etc. As is, the alignment is a tad out of spec for the toe. They said it's really close but not quite perfect.
And if someone wants to get a used set from a sedan, I believe all they would need would be a set of Wagon specific springs for the rear. Someone correct me if i'm wrong on this one.
Edited by Duffman
