dwbaily Posted May 9, 2018 Share Posted May 9, 2018 Was wondering if anyone else is or has experienced your transmission clunking when it downshifts and sorta hard shifts usually between 1st and 2nd it seems? I have a '13 Legacy 3.6 Auto. Thought once upon a time I read something that mentioned a computer flash or something is available to fix that. Haven't had the car long so didn't want to keep on driving it and possibly creating more slop if there's a fix. Thanks for any thoughts. Link to comment Share on other sites More sharing options...
Scubaboo Posted May 9, 2018 Share Posted May 9, 2018 I dont have that much experience with Subaru trannys but I would maybe check for codes, clear any, and/or remove the battery terminal for a few minutes to clear adaptations and see if anything changes? Link to comment Share on other sites More sharing options...
Timothy.B Posted May 10, 2018 Share Posted May 10, 2018 There is a hard 2nd to 1st shift but I thought it was the older years. I found Perscitus' post: http://legacygt.com/forums/showpost.php?p=5385260&postcount=22 I'd see if the dealership can check if it's updated and if they can do it for you. Timothy.B's 2011 LEGACY 3.6R Link to comment Share on other sites More sharing options...
FLlegacy Posted May 10, 2018 Share Posted May 10, 2018 It seems to be a common issue with all 5eats so I would have the dealer look at it as long as its under warranty. Link to comment Share on other sites More sharing options...
dwbaily Posted May 10, 2018 Author Share Posted May 10, 2018 Thanks guys for the info. Will check with dealer on mine and my son's 2011. May try that replacement mount too if it wouldn't void the warranty. You know how the dealers can be with aftermarket parts. Link to comment Share on other sites More sharing options...
islandborn Posted May 10, 2018 Share Posted May 10, 2018 bad valve body causes a similar issue. Link to comment Share on other sites More sharing options...
FLlegacy Posted May 10, 2018 Share Posted May 10, 2018 And a new valve body is generally the fix, but if its under warranty I would let the dealer fix it. Fresh fluid has been known to help as well as a relearn. But the issue tends to come back as the fluid ages. Link to comment Share on other sites More sharing options...
dwbaily Posted May 10, 2018 Author Share Posted May 10, 2018 Hmmm....only 39,000 miles but I guess parts have a mind of their own. I understand tranny fluid in our Legacy's is good for 100,000 miles? Link to comment Share on other sites More sharing options...
dwbaily Posted May 10, 2018 Author Share Posted May 10, 2018 Crap! Looked up what a valve body looked like and saw that that thing lists for like $800! Watched a YOUTUBE video and it looked fairly easy to replace. Of course it was out of the car and on a bench. I can imagine the dealer trying to get out of replacing it. Just hoping they're able to duplicate it when they test drive it. Hate the could not duplicate dance! Fortunately I bought the Wrap warranty coverage that's good out to 100,000 miles or 7 years from date it entered service in Dec of 2012 with $0 deductible. Only gonna last like 18 months. Cost me $1,000 and if the valve body is BAD I'll get that $1,000 back in one job! Guess I better get on their calendar and let them start looking into it. Link to comment Share on other sites More sharing options...
FLlegacy Posted May 11, 2018 Share Posted May 11, 2018 Hmmm....only 39,000 miles but I guess parts have a mind of their own. I understand tranny fluid in our Legacy's is good for 100,000 miles? I am not sure where you got that information from, but I wouldn't run the 5eat more than a couple years between changes. The fluid isn't terribly expensive, especially not compared to that valve body. And remember the warranty only applies if you are performing all recommended maintenance. Link to comment Share on other sites More sharing options...
dwbaily Posted May 11, 2018 Author Share Posted May 11, 2018 I TOTALLY agree on keeping clean fluid in it. My motto is clean oil never hurt anything. Heard that from a Japanese Subaru mechanic I'm pretty sure. He said the same about changing antifreeze but I coulda gotten my wires crossed. Will check owners manual on recommended tranny fluid change. Thanks for heads-up. Link to comment Share on other sites More sharing options...
