2006 Spec B differential VS 2007 GT differential
2tall4all
The 5EAT and the 5MT/6MT transmissions have different rear differentials, both in type and final ratio. Some exceptions though few.
You cannot mix these two (auto trans/man diff) unless you ensure the ratios match. Otherwise you would have a driven mismatch between the front axle and the rear. Something would break...quickly.
I'm looking for my PDF that shows the differences. Will link it if I find it.
^not exatly.
05-06 5mt including the 06 spec b cars used a VLSD with 4.11 ratio R160
05-06 5eat cars used the same VLSD but with 3.92 R160
07-09 5mt and 5eat cars used a VLSD r160 w/ 3.92 gears
07-09 6mt spec B used a R180 with a torsen and 3.92 gears.
so for the OP, the 06 spec b and 07 gt both use a rear VLSD in R160 flavor, but the gearing is different. the only upgrade would be to find a 07-09 spec b R180 and rear axles. aside from that, you can have your rear end built with an aftermarket quaife or clutch type unit and retain your 3.92 gearing.
^not exatly.
Which is why I was looking for the PDF I created. It spells everything out. Edited my post for clarity. :)
