scottmor31 Posted January 21, 2009 Share Posted January 21, 2009 ok guys i need some help, just got my tranny back in. I have an 08 spec b. I installed a sti flywheel and clutch from act, my problem is the slave cylinder isnt traveling far enough to release the clutch, Any input? It Pushes the clutch fork but not nearly far enough. HELP Link to comment Share on other sites More sharing options...
scottmor31 Posted January 21, 2009 Author Share Posted January 21, 2009 Ohh i already blead the clutch line Link to comment Share on other sites More sharing options...
WhatV8 Posted January 21, 2009 Share Posted January 21, 2009 Is the overall thickness from the crank mounting flange to the tips of the pressure plate fingers the same between your stock and STI/ACT units? As long as you are certain all is good with the flywheel/clutch and throwout bearing setup, call ACT and ask them why their clutch isn't working properly with your specific setup. They would be a good place to start. Link to comment Share on other sites More sharing options...
scottmor31 Posted January 21, 2009 Author Share Posted January 21, 2009 This isnt specifically for my car but there have been numerous threads that say the sti clutch works in the spec b Link to comment Share on other sites More sharing options...
Turninconcepts Posted January 21, 2009 Share Posted January 21, 2009 The STi clutch does work. Did you reinstall the pivot pin in the clutch fork? Link to comment Share on other sites More sharing options...
scottmor31 Posted January 21, 2009 Author Share Posted January 21, 2009 yeah everything was installed as it came out as far as i can tell, yet when i push the clutch in it falls to the floor and does not come back Link to comment Share on other sites More sharing options...
scottmor31 Posted January 21, 2009 Author Share Posted January 21, 2009 is there an adjustment to make the slave cylinder extend further Link to comment Share on other sites More sharing options...
scottmor31 Posted January 23, 2009 Author Share Posted January 23, 2009 well guys sorry for the wild goose chase, i found the flaw in my install. I trusted one of my buddies when he said he knew how to bleed a clutch. there was so much air in the slave cylinder it wasnt even funny. Wow what a difference in a slipping clutch to an act clutch. Its really grabby but no chatter or squeal, so for freshly installed im very happy Link to comment Share on other sites More sharing options...
kevkel33leg05 Posted January 23, 2009 Share Posted January 23, 2009 wish i saw this earlier i would of told you to bleed it again. The clutch pedal sticking to the floor is a dead give away. Just be sure to break in that new clutch or you'll be back down there again. Link to comment Share on other sites More sharing options...
WhatV8 Posted January 29, 2009 Share Posted January 29, 2009 The pedal staying on the floor would have been a good clue to start with. Glad you found the issue before smoking your new clutch. Enjoy! Link to comment Share on other sites More sharing options...
