xtea Posted October 18, 2018 Share Posted October 18, 2018 I've got 3" exhaust, no cats, with two vibrant resonators and Avo Wagon mufflers. Its too loud but I don't want less power. I want more. Going to hit 500hp next summer. I am wondering if putting a high flow cat into each side of the Y pipe would have the effect of lowering sound, helping with emissions, and keeping restriction down. I know that a high flow cat has little effect on 300hp but definitely has an affect at 350hp and up. I'm thinking if I divide the exhaust flow between two high flow cats that instead of all of it through one that it would solve all the problems without having to go the route of an exhaust cut out. Let me know your thoughts. Cheers Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 18, 2018 Share Posted October 18, 2018 You always want more power . Link to comment Share on other sites More sharing options...
xtea Posted October 18, 2018 Author Share Posted October 18, 2018 You always want more power . Eh.... I have been sitting on a 7163 (with quick spool!) for a few months now. Just waiting for money for the tune and modified exhaust. Also I got beat by a golf last week with my 6758. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 18, 2018 Share Posted October 18, 2018 Golf R? Modified? Link to comment Share on other sites More sharing options...
xtea Posted October 18, 2018 Author Share Posted October 18, 2018 Golf R? Modified? Debadged, quieter then my ride. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 18, 2018 Share Posted October 18, 2018 Sneaky guy. K back on topic. I don't know the answer to your original question . Hopefully, someone will chime in. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 19, 2018 Share Posted October 19, 2018 Don't cats work on temperature, I thought they had to be near the hot exhaust ? You might need to find a performance muffler to add in the mid pipe. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
utc_pyro Posted October 19, 2018 Share Posted October 19, 2018 Rally cars tend to run their cats right at the exhaust tips. It won’t be as efficient back there from the emissions prospective though because it’ll take a while for the cats to heat up enough to start the reaction. Once they start the conversion is exothermic, so they should keep themselves active at anything above idle. Link to comment Share on other sites More sharing options...
Keyan Posted October 19, 2018 Share Posted October 19, 2018 i doubt they'll get hot enough unless you heat wrap the entire exhaust up to where the cats are. Link to comment Share on other sites More sharing options...
JmP6889928 Posted October 19, 2018 Share Posted October 19, 2018 Try wrapping the pipes all the way back. I wrapped mine all the way to the Y pipe and it quieted the cabin down quite a bit. Link to comment Share on other sites More sharing options...
lilredwagon Posted October 20, 2018 Share Posted October 20, 2018 I think it would be fine. If you've played with different restrictions in an exhaust system, you'd see that any point of restriction is where the heat builds up. So if you put the cat(s) in the midpipe, the heat would sit right in front of them, and they're heat enough to do their job. Especially if you use an aftermarket, hi-flow cat. They usually only work at startup, and the egts of a Subaru turbo motor are out of range of most cats, so they still smell. (Subaru egts are in the ~1400 range, while most cars are in the ~1100 - 1200 degree range). So the distance from the turbo would actually work in their favor. And if you got (2x) 3" hi-flow cats, I'd imagine they are meant for larger motors, which typically run lower egts. I'd say go for it! I'm probably going to do something similar with an aftermarket cat in the downpipe, and a 100 cell in place of the resonator. Link to comment Share on other sites More sharing options...
