g.capps Posted October 17, 2018 Share Posted October 17, 2018 Hey friends, my 05 Legacy GT has developed an issue. After a long drive or when the engine reaches its normal operating temperature and I shut it off coolant overflows from the coolant reservoir. I've also noticed that the top radiator hose has no pressure. I've replaced both radiator caps, had a pressure test of the radiator (all good) and have burped the system. Any ideas or answers as to what may be the problem would be greatly appreciated. Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
rhino6303 Posted October 17, 2018 Share Posted October 17, 2018 Hydrocarbon test for headgaskets. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 17, 2018 Share Posted October 17, 2018 X2 to that. Most repair shops will have a HC tester. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted October 18, 2018 Share Posted October 18, 2018 Yup Link to comment Share on other sites More sharing options...
