Mr.RMFC Posted October 14, 2018 Share Posted October 14, 2018 Hey guys What transmissions will be a direct swap to a 2005 legacy gt? I am aware any swap requires a matching ratio rear diff. To start off. Would a 2021 wrx trans and rear diff swap in? Link to comment Share on other sites More sharing options...
Max Capacity Posted October 15, 2018 Share Posted October 15, 2018 With enough money, anything is possible. Where dose one buy a 2021 WRX tranny? May be in the movie, Back to the Future In the top of the tranny forum there is a sticky that should help you out. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Mr.RMFC Posted October 15, 2018 Author Share Posted October 15, 2018 *2011 wrx trans. Where is this thread Link to comment Share on other sites More sharing options...
Max Capacity Posted October 15, 2018 Share Posted October 15, 2018 https://legacygt.com/forums/showthread.php/transmission-gear-ratios-and-final-drives-229267.html Does that help ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
natemj Posted October 23, 2018 Share Posted October 23, 2018 YES IT DOES. Thank you for all your contributions Max Capacity! Link to comment Share on other sites More sharing options...
Max Capacity Posted October 23, 2018 Share Posted October 23, 2018 YES IT DOES. Thank you for all your contributions Max Capacity! 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
