hadvw Posted June 30, 2019 Share Posted June 30, 2019 (edited) 3 weeks ago, my LGT started making really bad noises from the drivetrain - I had been running a flat tire without noticing it for 2-3 days, and I think that did it in. Very bad clunking noises, I think either from center or rear diff. With some combination of diff / driveshaft / transmission, could maybe be fixable, but has some other "annoying" issues like the HVAC actuators being noisy, CD player dying, etc. Engine was running strong. Burnt some oil, as is normal, but was pulling quite nicely - has a bnr16g (one of the originals in the vf40 housing, so you can leave it in for SMOG!). I'm swamped at work, and I don't have a ton of time to pull parts, so I'm offering this first as a "buy everything" special for locals - way below the price of buying everything separately. That way, if you want a good deal on performance parts or other stuff, and you have the time, today's your lucky day. I just need to clear up space, etc. If it doesn't sell in a week or two, I'm going to pull the easy parts and sell those separately, and then have a wrecker haul it away. I'm going to list the estimated price for various parts that I would pull off the car to sell with a "quick sale price", just so you see where I am getting my price from - THESE ESTIMATES DO NOT INCLUDE SHIPPING. If I list the price as (-), then I don't plan on pulling the part or not worth selling, so it's a "bonus" part. Whether that means anything is up to you - I just want to list everything that's been done to the car. OK... Just those prices add up to ~$4500, give or take. I'm sure I'm way overestimating my prices. So let's cut 33% off. $3000 OBRO takes everything, you arrange for transportation (car will need to be towed). That's not even counting the engine, etc. Edit: Rotas sold, price can be adjusted some.. (sale of everything currently pending) VIN: 4s3bp676354332564 Car as it sits has the following parts on it: Performance / ECU: bnr16g, 80k miles, never had a problem. In OEM VF40 housing ($300) Infamous Performance and Tuning Oil Line kit. No longer made. ($100) dw650cc sidefeed injectors, may need a cleaning ($150) Walbro pump (-) Tuning Alliance open source tune (several revisions) (-) Grimmspeed TMIC - coated black, everything in great shape except for one hose with some wear from the clamp digging in ($600) STI up ($50) CNT Racing catted downpipe ($200) Hexmods F1 valve body (may or may not pull - $500) Suspension: Cobb sway bars, front and rear, no longer made. Includes full new bracket / bushing set made by a member on here which are bigger than original. Comes with Cobb (Hotchkiss?) reinforcement bracket. Generally in good shape, no picture (on the car). Several end links, some OEM-like, some performance but used. $250 RCE T1 Tarmacs. Only the rears on the car right now, fronts were trying to get a dust cover on them that had worn out. Stripped the top nut a bit on one - KW will rebuild/revalve/whatever. But should also be fine for driving as is. Need to be adjusted/levelled. ($600) OEM wheels with Michelin Pilot Sport 225/45/17 - barely run (see other set of tires later - those were what was mostly driven), one or two have a patch due to nails, so not for track, but auto-x or other daily should be great. Probably 7-8/32s tread left. Great tires. ($400) OEM wheel + Pilot A/S 225-45x17 as full-size spare. ($50) Brakes: Wilwood front caliper upgrade. Comes with extra set of brackets. R4-S pads, Wilwood "B" pads, rears are currently R4-S. Includes 3mm spacers for the front to clear OEM wheels. Cryo Centric OEM rotors.Front SS brakes lines ($300) Grimmspeed Master cylinder brace ($50) AVO front grill, cut to fit, not great, but ok. ($100) Digboost20 digital boost gauge, but starting to die - or may be related to CD dying. (-) HID upgrades to headlights (-) All interior lights upgraded to LED (-) Fumoto valve (-) Redline hood struts ($50) ----------------- Parts also included, but not ON the car right now. Exhaust: -OEM UP ($25) -OEM DP, gutted mid ($200) -OEM mid DP WITH cat (just the half with a cat) ($150) OEM TMIC, Half "Bulletproof" mod, half my own mod. A little clunky, but gets the job done - has never had the fingers come loose. No pic. $50. Brakes: -OEM front calipers + 1 or 2 used set of pads + 2 more sets of rotors with left left - one pair slotted, one pair Centric OEM, front OEM lines - $200 NIB Stoptech Rear OEM-size pads. $25 Free Range Racing full silicone hose replacement kit. Used one hose to replace the FPR line. Other than that, full kit + "I goofed" replacement hoses, so some extras, etc. All the documentation is there, etc. $125 (was > $200 new, no longer made). Rear shock mounts + longer screws + spacers to fix "saggy butt" - never put on. ($50) OEM springs + Koni shocks (the front set is on right now) - 70-80k miles. Pre-cut, so you could easily replace with new Konis, no need to cut OEM shocks. Still ok to drive for a while. ($250) Another set of full OEM springs - someone threw these in when I bought his OEM wheels. Unknown mileage. Could be used for Konis. ($100?) OEM sways - free? Rota wheels, 17x8.5, fit fine without spacers. More Pilot Super Sports on them in 225/45-17. Can mix-and-match with the others. One tire totally dead due to driving on it while flat. So 7 Super Sports total. Wheels have curb rash and a bit beat up, but hold air, etc. ==> SOLD! 2 OEM wheels, no tires. Hold air, but aren't in good shape. $25 each. AVO sway bar reinforcement brackets - had a brain cramp, bought when not needed - still new in packaging (no pic). $35 AVO Turbo Inlet - new over $225, still new in box - $125 Non-cubby center console cover for doing Nexus 7 upgrade. Never had time to finish it. $100 Nexus 7 2013 16GB + 12V->5V conversion amp + cables to charge/run + USB hub. $50. Cubbypod Cubby gauge holder "left over" pod. $10 OEM grill + OEM "gutted" grill - $25 each OEM passenger headlight housing. Tried to do the "clearing" myself, didn't like it, bought a new one. Not great, but not horrible. $50. Various oil filters, including 5 OEM "black" filters I just bought off a member here. $50 Various other parts: gas cap (broken strap), OEM headlight housing covers to go back to stock if you remove the HID upgrade, etc.. Edited July 20, 2019 by hadvw Formatting Link to comment Share on other sites More sharing options...
hadvw Posted June 30, 2019 Author Share Posted June 30, 2019 More pics.. Link to comment Share on other sites More sharing options...
hadvw Posted June 30, 2019 Author Share Posted June 30, 2019 And more... Link to comment Share on other sites More sharing options...
hadvw Posted June 30, 2019 Author Share Posted June 30, 2019 Last batch.. Sorry, tried to have most of it make sense. Ask if anything is unclear. Link to comment Share on other sites More sharing options...
rhino6303 Posted June 30, 2019 Share Posted June 30, 2019 I'd really like the willwood brake calipers with ss lines if you pull them. Thanks. Link to comment Share on other sites More sharing options...
hadvw Posted June 30, 2019 Author Share Posted June 30, 2019 I wasn't planning on making a list of "dibs" yet, but I guess you can be first on there.. However, just be aware that if someone comes along and says "I'll take all of it", they'll get first crack at everything, even things with "dibs".. Link to comment Share on other sites More sharing options...
Notorious Posted July 1, 2019 Share Posted July 1, 2019 I sent you a PM about all your brake pads. Link to comment Share on other sites More sharing options...
boxkita Posted July 1, 2019 Share Posted July 1, 2019 I wish I had more time, I'd take the whole thing. Not that I'm of help to you. Transportation up here would be 500-900. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
hadvw Posted July 1, 2019 Author Share Posted July 1, 2019 I wish I had more time, I'd take the whole thing. Not that I'm of help to you. Transportation up here would be 500-900. We could go half/half? Link to comment Share on other sites More sharing options...
hadvw Posted July 1, 2019 Author Share Posted July 1, 2019 I think I've replied to all the PMs. Link to comment Share on other sites More sharing options...
Guest Posted July 1, 2019 Share Posted July 1, 2019 Don't send it to wrecker! This wagon is worth saving. Sell the whole thing as is. Link to comment Share on other sites More sharing options...
hadvw Posted July 2, 2019 Author Share Posted July 2, 2019 Don't send it to wrecker! This wagon is worth saving. Sell the whole thing as is. That's what this post is for - everything for $3000. Who's up for it? Someone in OR want to go halfsies with Boxkita? There's at least $4-5k of "used pricing" parts in there, even if there is some overlap. If I add up what I paid for these parts.. I don't even want to think about it.. Over $2k in the last 3 years just for the Hexmods F1, RCE Tarmacs and Wilwoods. But I don't have a huge driveway or garage, new car is here, wife is looking for a new (3rd) car so she doesn't have to drive the minivan in the city all the time, etc.. Work is busy, time is money, I don't have a week to pull all the parts, hence the huge discount for taking everything. Link to comment Share on other sites More sharing options...
hadvw Posted July 2, 2019 Author Share Posted July 2, 2019 One more part I just remembered - Killer Bee oil intake. Obviously not pulling. Link to comment Share on other sites More sharing options...
Enlight Posted July 2, 2019 Share Posted July 2, 2019 PM'd for silicon hose kit! muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted July 2, 2019 Share Posted July 2, 2019 In the event of a part-out, PM'd about the Nexus. I second UncleMat, that's a nice looking wagon, would hate to see it go to the yard, but I get not having time to work on it... Link to comment Share on other sites More sharing options...
KRYPTO Posted July 23, 2019 Share Posted July 23, 2019 Turbo inlet hose? Link to comment Share on other sites More sharing options...
hadvw Posted July 23, 2019 Author Share Posted July 23, 2019 Sale of everything is pending, hopefully this week. Buyer plans to sell a bunch of the parts. Link to comment Share on other sites More sharing options...
boxkita Posted July 27, 2019 Share Posted July 27, 2019 Good for you. Let me know if it falls through, I'd be able to come get it in a couple of weeks. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Enlight Posted July 31, 2019 Share Posted July 31, 2019 Sad I can't get those hoses (at least not now) but glad you got the solution you were looking for. GLWS! muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
hadvw Posted September 10, 2019 Author Share Posted September 10, 2019 Tentatively sold to an in-town mechanic. Waiting for paperwork, etc. Will have a few left-over parts to sell eventually. Link to comment Share on other sites More sharing options...
lbwilliams44 Posted September 18, 2019 Share Posted September 18, 2019 (edited) Where in OR? I would consider buying it because I need a lot of the parts you listed.. especially if someone wanted to split it. Specifically: Front and Rear Brakes (all of it), Turbo, Oil Feed, Hoses, Fuel Pump/Injectors, and probably one of the TMICs you have on there. Would pull parts myself if that helps. And if that sale goes through and he is parting it out as well, I would be open to working with them if they are selling parts. Brakes , Fuel bits, and Turbo are the biggest points of interest as mine are getting to that replace point. Edited September 18, 2019 by lbwilliams44 Link to comment Share on other sites More sharing options...
lbwilliams44 Posted September 18, 2019 Share Posted September 18, 2019 Just realized i misread, someone in OR wants to split it. Car is in CA. If someone wanted to split it in OR, I would be interested. Link to comment Share on other sites More sharing options...
hadvw Posted September 19, 2019 Author Share Posted September 19, 2019 As I said - waiting for official DMV paperwork, and then I'll be mostly done with it. I will probably have Avo inlet, Avo brackets, Freerange hoses, Nexus stuff, cubbypod and a few other miscellaneous items to sell in a couple of weeks, once everything gets settled. Work is so busy right now.. Link to comment Share on other sites More sharing options...
pdXammo Posted October 23, 2019 Share Posted October 23, 2019 Let us know if she found a new home and what you have left please? Link to comment Share on other sites More sharing options...
hadvw Posted October 23, 2019 Author Share Posted October 23, 2019 Yes, new home has been found - mechanic down the street who wanted it as a personal car.. He brought cash, towed it a few days later, haven't heard from him since.. Need to check paperwork eventually :-) Kept a few parts to supplement reduced sale price :-) Here's what's left. I think this is mostly it, except for a few popits, etc. -Free Range Racing hoses (missing one 3 or 4 mm hose I used for the FPR), includes the "updated" kit that re-did some hoses. $175 + ship. -front right headlight. Definitely restoreable. $50 + ship. -Avo Turbo inlet, NIB. $175 + ship. Link to comment Share on other sites More sharing options...
