gimpydingo Posted July 12, 2019 Share Posted July 12, 2019 Cleaned off some grease from my rear diff on my '13 3.6. I learned the diff bushings are grease packed. Glad it's a bushing and not my diff leaking. Link to comment Share on other sites More sharing options...
amusa Posted July 13, 2019 Share Posted July 13, 2019 New driver window regulator is in. Took less then an hour. The window is finally working. The original motor locked up. Link to comment Share on other sites More sharing options...
Scooby Fan Posted July 13, 2019 Share Posted July 13, 2019 Car is washed and detailed....lawn is mowed and edges are trimmed.... Time for a cold beer, or so Link to comment Share on other sites More sharing options...
Zee199969 Posted July 14, 2019 Share Posted July 14, 2019 Does anyone have the part# for the front bumper cover brackets that hold the sides of the front bumper near the headlights in place? I remember it being posted on here at one time, but I can't find it via search. My "Build" Link to comment Share on other sites More sharing options...
DugsSin Posted July 14, 2019 Share Posted July 14, 2019 This part ? https://parts.subaruonlineparts.com/oem-parts/subaru-corner-support-57707aj53a/?c=Zz1ib2R5JnM9YnVtcGVyLWFuZC1jb21wb25lbnRzLWZyb250Jmk9NzUyNjAwNTUmcj00JmE9c3ViYXJ1Jm89bGVnYWN5Jnk9MjAxMCZ0PTItNWd0JmU9Mi01bC1oNC1nYXM%3D Link to comment Share on other sites More sharing options...
Sarang Posted July 14, 2019 Share Posted July 14, 2019 That's the part that solved my issue with the bumper popping out at that corner on both sides. Link to comment Share on other sites More sharing options...
Zee199969 Posted July 14, 2019 Share Posted July 14, 2019 (edited) This part ? https://parts.subaruonlineparts.com/oem-parts/subaru-corner-support-57707aj53a/?c=Zz1ib2R5JnM9YnVtcGVyLWFuZC1jb21wb25lbnRzLWZyb250Jmk9NzUyNjAwNTUmcj00JmE9c3ViYXJ1Jm89bGVnYWN5Jnk9MjAxMCZ0PTItNWd0JmU9Mi01bC1oNC1nYXM%3D Thanks DugSin! I'm going to be pulling my front bumper for the 3rd time, figured it be a good time to swap out that bracket because it's not expensive. Edited July 14, 2019 by Zee199969 My "Build" Link to comment Share on other sites More sharing options...
dgoodhue Posted July 14, 2019 Share Posted July 14, 2019 I did my timing belt for the 2nd time this past week. I forgot the seal on the side of the water pump. I did it over two days. The timing belt is together and I went as far as I could. I am just waiting for new exhaust manifold gaskets. Link to comment Share on other sites More sharing options...
GTEASER Posted July 14, 2019 Share Posted July 14, 2019 Lamin-X light smoke overlays on the reverse/indicator portion of the tails. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
creep_nu Posted July 15, 2019 Share Posted July 15, 2019 just rolled over 150k miles!! so that's fun. changed the oil(as well as the oil in my parents 3 cars and my brother's car because somehow we all needed oil changes at the same time...) and did a full brake job on my parents acura. hooray for a long day. i used the RX-8 2009+ oil filter for a bit extra oil capacity(looks to be about double the size of the OEM filter), but it hangs so low and close to the exhaust manifold that i'm unsure if i'll be using it again...we'll see. Link to comment Share on other sites More sharing options...
x1conroe Posted July 15, 2019 Share Posted July 15, 2019 Picked up this set from eBay. I pulled the bumper and old headlights apart and realized that the H7s do not fit in the low beam projector housing. After doing some research, i found them on another website - https://www.carid.com/2013-subaru-legacy-headlights/lumen-factory-style-headlights-2051170194.html. They call for H1s. I went to autozone to get some H1s. The wiring harness has two prongs and the H1s have one pin? I'm currently looking for a bulb that will work. Car is still apart and I rode my bike to work. Link to comment Share on other sites More sharing options...
dgoodhue Posted July 15, 2019 Share Posted July 15, 2019 I am pretty sure they are just H7's for the low beams. Link to comment Share on other sites More sharing options...
x1conroe Posted July 15, 2019 Share Posted July 15, 2019 I am pretty sure they are just H7's for the low beams. Here's a pic of the OEM low beam projector Two pics of the aftermarket ones Link to comment Share on other sites More sharing options...
Humble Rumble Posted July 15, 2019 Share Posted July 15, 2019 (edited) Those are the ebay version with clear sidemarkers that have been posted all over the Facebook group. They're confirmed as H1 for the low beams. Edited July 16, 2019 by Humble Rumble 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
x1conroe Posted July 16, 2019 Share Posted July 16, 2019 Those are the ebay version with clear sidemarkers that have been posted all over the Facebook. They're confirmed as H1 for the low beams. Thanks Humble. I'm no longer on facebook. Link to comment Share on other sites More sharing options...
dgoodhue Posted July 16, 2019 Share Posted July 16, 2019 OK I understand. I didn't realize that you had aftermarket lights (or that the bulbs were different) I just assume those were a used set of OEM's lights from ebay. Link to comment Share on other sites More sharing options...
Falcor Posted July 16, 2019 Share Posted July 16, 2019 It's sad that the plastic on the headlights degrade that quick. Mine are starting to show some degradation, but it has been garaged most all its life. Probably keeps the UV's to a minimum. I did have the headlights on the Outback cleaned up. They looked quite a bit better, and of course I waited until I was ready to sell it. Link to comment Share on other sites More sharing options...
Niko0422 Posted July 17, 2019 Share Posted July 17, 2019 (edited) I washed, claybar, and waxed it. I’m also looking into aftermarket headlights and found this https://www.protuninglab.com/hidxe20suoul.html Anyone has any experience with them ? Edited July 18, 2019 by Niko0422 Figured how to load pic Link to comment Share on other sites More sharing options...
SchwarzeEwigkt Posted July 17, 2019 Share Posted July 17, 2019 I received a new idler pulley, serpentine belt, and tensioner to be replaced this weekend along with another drain and refill of transmission fluid. Not exciting, but necessary! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted July 17, 2019 Share Posted July 17, 2019 It's sad that the plastic on the headlights degrade that quick. Mine are starting to show some degradation, but it has been garaged most all its life. Probably keeps the UV's to a minimum. I did have the headlights on the Outback cleaned up. They looked quite a bit better, and of course I waited until I was ready to sell it. raise the hood up a bit when you wax it and the headlights will last longer before yellowing... since my car sits in the sun all day, I am starting to see the plastic change colors when I look at it with polarized glasses... Link to comment Share on other sites More sharing options...
coco26 Posted July 17, 2019 Share Posted July 17, 2019 I’m also looking into aftermarket headlights and found this https://www.protuninglab.com/hidxe20suoul.html Anyone has any experience with them ? As far as I know, most members on here that have them (like me) get the ebay version, and buy their own bulbs to put in. I have led's in mine. Link to comment Share on other sites More sharing options...
13Legacy01 Posted July 17, 2019 Share Posted July 17, 2019 For what it’s worth - I’ve used the Meguiar’s headlight restoration kit with great success. Before: After: Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Falcor Posted July 18, 2019 Share Posted July 18, 2019 raise the hood up a bit when you wax it and the headlights will last longer before yellowing... since my car sits in the sun all day, I am starting to see the plastic change colors when I look at it with polarized glasses... Thanks for the tip. Now I just have to get around to finally waxing it. Link to comment Share on other sites More sharing options...
Loya1ty Posted July 26, 2019 Share Posted July 26, 2019 Got my name added to the title with my wife and transferred my custom plate to the car . (now I just need to find a black GT for sale and I can just swap them on the way home.. she'll never know) also. huzzah for post 100! Link to comment Share on other sites More sharing options...
Falcor Posted July 30, 2019 Share Posted July 30, 2019 Tried to install the drivers side mirror (broke original on garage door frame), but the new one didn’t line up correctly. I contacted the seller this morning. Thankfully it was on Amazon, so I feel better about it being taken care of. Replacement: Factory: Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
