LGTCutie Posted November 13, 2020 Share Posted November 13, 2020 Hey im looking at getting a catless uppipe but i am also thinking about swapping the stock turbo to a BNR 18G with all the supporting mods as well but the turbo will wait until springtime. Im a new owner and the car has 247, xxx kms right now so the uppipe is a priority. My question is it better to go with solid or flexed? And can i use a high flow uppipe with a 2inch diameter on stock turbo or is that not good? And is the regular 1.75 inch good enough to maximize the 18g or will i just need to get another uppipe down the road. Thanks for the help appreciate it. Sent from my SM-G930W8 using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted November 13, 2020 Share Posted November 13, 2020 Look through the for sale forum on NASIOC and find a OEM up pipe from a STI. They were catless and will last forever. I'm not a big fan of the flex joint, they always end up leaking at some point. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LGTCutie Posted November 14, 2020 Author Share Posted November 14, 2020 Look through the for sale forum on NASIOC and find a OEM up pipe from a STI. They were catless and will last forever. I'm not a big fan of the flex joint, they always end up leaking at some point.Do you know if a forester xt uppipe would fit? Sent from my SM-G930W8 using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted November 14, 2020 Share Posted November 14, 2020 Seems like it should fit these are all the same basic set up. Look online at some of the vendor sites and see if they list the same Invidia Up pipe for the cars. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted November 21, 2020 Share Posted November 21, 2020 I have a new in box Invidia catless up pipe and a catless up pipe from a WRX if you're interested in either. Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 21, 2020 Share Posted November 21, 2020 Beware of Grimmspeed UP as I just had one fail at the flex joint and I don't even drive my car in the winter. Rusted through the flex joint and also the so-called stainless woven material over the flex joint. It was only about 3.5 years old too. Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 21, 2020 Share Posted November 21, 2020 Hey im looking at getting a catless uppipe but i am also thinking about swapping the stock turbo to a BNR 18G with all the supporting mods as well but the turbo will wait until springtime. Im a new owner and the car has 247, xxx kms right now so the uppipe is a priority. My question is it better to go with solid or flexed? And can i use a high flow uppipe with a 2inch diameter on stock turbo or is that not good? And is the regular 1.75 inch good enough to maximize the 18g or will i just need to get another uppipe down the road. Thanks for the help appreciate it. Sent from my SM-G930W8 using Tapatalk You had better plan on injectors and fuel pump too. 18G is a pretty large step up from a VF40 and you'll definitely need a custom tune. Why are you going to go to 18G? A lot of potential lag but you'll be able to go 150 mph. Link to comment Share on other sites More sharing options...
shralp Posted November 21, 2020 Share Posted November 21, 2020 I’d suggest a JMP built VF52 or 16g Link to comment Share on other sites More sharing options...
Max Capacity Posted November 21, 2020 Share Posted November 21, 2020 Beware of Grimmspeed UP as I just had one fail at the flex joint and I don't even drive my car in the winter. Rusted through the flex joint and also the so-called stainless woven material over the flex joint. It was only about 3.5 years old too. I will agree, I never liked the flex joints. even from the factory. I see Subaru has a issue with them on the 2015's Outbacks. https://www.subaruoutback.org/threads/17-outback-exhaust-manifold-leak-at-flex-joint.526816/#post-6038878 GF's 08 Ford had the flex joint go back in 2014, not many miles on the ford either. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LGTCutie Posted November 22, 2020 Author Share Posted November 22, 2020 You had better plan on injectors and fuel pump too. 18G is a pretty large step up from a VF40 and you'll definitely need a custom tune. Why are you going to go to 18G? A lot of potential lag but you'll be able to go 150 mph.Plan is to do injectors pump, downpipe and custom tune all at the same time. I wasnt sure which would be better the 16g or 18g so naturally at the same price point i assumed more horsepower would be better. My main goal is to smoke Ecoboost mustangs and make some BMW owners cry. Sent from my SM-G930W8 using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted November 22, 2020 Share Posted November 22, 2020 Is this car have a 5mt or a 5eat ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LGTCutie Posted November 22, 2020 Author Share Posted November 22, 2020 Is this car have a 5mt or a 5eat ?5EAT Sent from my SM-G930W8 using Tapatalk Link to comment Share on other sites More sharing options...
HDTurbo Posted November 22, 2020 Share Posted November 22, 2020 I had Invidias on 2 LGTs and both cracked at the upper flange within less than 5 years. Link to comment Share on other sites More sharing options...
LGTCutie Posted November 23, 2020 Author Share Posted November 23, 2020 I had Invidias on 2 LGTs and both cracked at the upper flange within less than 5 years.I went with the Perrin one because everyones been saying the invidias are known for failure Sent from my SM-G930W8 using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted November 23, 2020 Share Posted November 23, 2020 5EAT Sent from my SM-G930W8 using Tapatalk Just thinking the 18g may be to much for the 5eat to handle over time. (?) Anyone else have thoughts ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
