Max Capacity Posted August 29, 2020 Share Posted August 29, 2020 (edited) Looking around the web today, I found this. look down the page, you'll see mufflers, and Y pipe, etc. https://www.summitracing.com/search/year/2005/make/subaru/model/legacy/department/exhaust?SortBy=BestKeywordMatch&SortOrder=Ascending&keyword= Link still works, Feb 12 2021, you should call them and make sure the correct length, see the picture shows the right side is longer... Edited February 12, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted October 2, 2020 Share Posted October 2, 2020 (edited) I bought one of these, https://www.amazon.com/Motive-Products-Pressure-Clutch-Bleeder/dp/B00CJ5DZE2 works great. Here's a thread about doing this. My update is at post #30 https://legacygt.com/forums/showthread.php/best-way-bleed-brakes-205026.html link still works, Feb 12 2021 Edited February 12, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boxkita Posted October 9, 2020 Share Posted October 9, 2020 replacement for jazzy mod that doesn't require a silent CD https://legacygt.com/forums/showthread.php/aux-stereo-input-just-do-like-257977.html?t=257977 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
JmP6889928 Posted October 21, 2020 Author Share Posted October 21, 2020 Thanks Max: http://candlepower.com/ Link to comment Share on other sites More sharing options...
rhino6303 Posted October 27, 2020 Share Posted October 27, 2020 DIY headlight sanding/clearing. Better than other diys. This guy is the lead painter at a shop and his channel is amazing. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 2, 2020 Share Posted November 2, 2020 https://www.mavalgear.com/maval/catalog-search That is the one my trusted mechanic said he would only use. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boxkita Posted November 19, 2020 Share Posted November 19, 2020 Subaru bulletin for replacement of airbag. tools list & order of use for even the most basic tech to follow. Using this procedure should take no more than 30 minutes, much less for an experienced tech. https://static.nhtsa.gov/odi/rcl/2016/RCRIT-16V358-5167.pdf I suggest printing this before going for your replacement. Or even taping it to the dash. Also suggest removing all your customizations to avoid complications. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 4, 2020 Author Share Posted December 4, 2020 Thanks Pleides for this link: https://driveshaftstore.com/Subaru-Legacy-Driveshaft-2005 Link to comment Share on other sites More sharing options...
Max Capacity Posted December 4, 2020 Share Posted December 4, 2020 Thanks Pleides for this link: https://driveshaftstore.com/Subaru-Legacy-Driveshaft-2005 See post 298 above 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 6, 2020 Author Share Posted December 6, 2020 Ooops...my apologies. Getting hard to keep track of everything now...LOL Link to comment Share on other sites More sharing options...
Max Capacity Posted December 6, 2020 Share Posted December 6, 2020 Ooops...my apologies. Getting hard to keep track of everything now...LOL I understand. I've been thinking about going through this thread and make a new index list...that would be a big job. Would need lots of paper and a good pen. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boxkita Posted December 6, 2020 Share Posted December 6, 2020 I understand. I've been thinking about going through this thread and make a new index list...that would be a big job. Would need lots of paper and a good pen. I used a spreadsheet Probably should have uploaded it when I made the first one Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
awfulwaffle Posted December 7, 2020 Share Posted December 7, 2020 (edited) Here's the cheapest bore gage I can find with the accuracy to give sensible values when measuring turbo EJ bores: https://www.mcmaster.com/20685A666/ Not too bad compared to some of the $1000+ options, though the accuracy is still a significant portion of the overall tolerance band. Still beats the hell out of taking 100+ measurements with telescoping gages and a mic since you'll be able to tell whether you're really centered in the bore within 2 tenths Edit: Amazon wins https://www.amazon.com/Mitutoyo-511-753-Bore-Gage-2923SB-10/dp/B00FJIH6IC/ref=mp_s_a_1_3?dchild=1&keywords=mitutoyo+bore+gauge&qid=1607307569&sprefix=mitutoyo+bore&sr=8-3#aw-udpv3-customer-reviews_feature_div Edited December 7, 2020 by awfulwaffle Link to comment Share on other sites More sharing options...
boxkita Posted December 17, 2020 Share Posted December 17, 2020 https://legacygt.com/forums/showthread.php/jdm-front-bumper-options-228408.html?p=4884377&highlight=ings#post4884377 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Max Capacity Posted December 23, 2020 Share Posted December 23, 2020 (edited) https://www.amazon.com/Motul-Gear-Fully-Synthetic-Gearbox/dp/B00N1ADTOA/ref=pd_lpo_263_img_1/146-9710055-8442908?_encoding=UTF8&pd_rd_i=B00N1ADTOA&pd_rd_r=efc1ff63-e175-4ad8-b8aa-fa2f4bcc91d5&pd_rd_w=D5G0o&pd_rd_wg=VXPOZ&pf_rd_p=7b36d496-f366-4631-94d3-61b87b52511b&pf_rd_r=RGP9NAFGBPJ77G4E0E53&psc=1&refRID=RGP9NAFGBPJ77G4E0E53 Not sure how long that price is good for, but this is the best fluid for 5 or 6 MT's and rear Diff's. Look around the page, just found 5qt's for $76.05 link still works Feb 12 2021 Edited February 12, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted December 31, 2020 Share Posted December 31, 2020 (edited) Found this for those fighting the pinch bolt at the lower ball joint. It might be less PITA to just replace the knuckle. https://www.google.com/search?q=2005+subaru+knuckle&rlz=1C1OKWM_enUS906US906&oq=2005+subaru+knuckle&aqs=chrome..69i57j0i22i30i457j0i22i30l6.8833j0j15&sourceid=chrome&ie=UTF-8 link still works Feb 12 2021 Edited February 12, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted February 4, 2021 Share Posted February 4, 2021 Got this link from the Outback Forum, https://www.maniacelectricmotors.com/subaru.html Look/scowl down the bottom of the page to find rebuild parts when you get to the starter or alternator page. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted February 9, 2021 Author Share Posted February 9, 2021 https://www.xprintstyle.com/collections/subaru-lph?fbclid=IwAR1NF_4dqB4b-YMxoR2Db37KRjKfKpz67NMdohP6wjMrD-6hyiNPk3z20mE Link to comment Share on other sites More sharing options...
Tehnation Posted February 13, 2021 Share Posted February 13, 2021 https://www.xprintstyle.com/collections/subaru-lph?fbclid=IwAR1NF_4dqB4b-YMxoR2Db37KRjKfKpz67NMdohP6wjMrD-6hyiNPk3z20mE Have you ordered from the site? I'm definitely about to spend 200 bucks on some kicks and a hoodie lol. What does LPH mean? Link to comment Share on other sites More sharing options...
JmP6889928 Posted February 13, 2021 Author Share Posted February 13, 2021 Have you ordered from the site? I'm definitely about to spend 200 bucks on some kicks and a hoodie lol. What does LPH mean? I have not ordered personally. This was on one of the other forums I frequent and I can't speak for legitimacy, however, I'm sure if it was a scam, someone would have immediately blown the whistle on it. Maybe you can search them and find a phone number and order that way? There definitely is some cool stuff on there. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 13, 2021 Share Posted February 13, 2021 Just an idea for those that have posted links in this thread. Can you go back and make sure the links still work ? You'll notice in most of my post with links I made "edits" yesterday. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boxkita Posted March 8, 2021 Share Posted March 8, 2021 304 stainless turbo exhaust port pieces as well as 304 exhaust port flanges for making your own headers http://www.rjes.com/html/exhaust_systems.html http://www.rjes.com/assets/images/P1000799.JPG Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Febreze Mee Posted March 8, 2021 Share Posted March 8, 2021 What a find! These should make the process of fabricating headers exponentially easier. Now, somebody who knows what they're doing, make a quality UEL! MILKRUN - Click Here Link to comment Share on other sites More sharing options...
jaylew Posted March 15, 2021 Share Posted March 15, 2021 Here is an alternative for the Vacuum T replacement. The McMaster unit is the bronze one on the right Wagon is LIFE! - 265,000 miles and climbing Unofficial Build (Restoration) Thread Steering Rack Rebuild Link to comment Share on other sites More sharing options...
Febreze Mee Posted March 15, 2021 Share Posted March 15, 2021 For those who appreciate factory fabric floor mats, you can pick them up brand new for about $75 shipped: https://www.subarupartspros.com/ & https://www.subaruonlineparts.com/ MILKRUN - Click Here Link to comment Share on other sites More sharing options...
