bombpockets Posted July 11, 2013 Share Posted July 11, 2013 So I LOVE my lgt, but I'm lusting after some forced induction and I know my engine can't handle real turbo boost, but what about lower boost from a centrifugal supercharger? I like the idea of low/consistent power gain. So I guess my question is has anyone done this? Is it a reasonable thing to do or am I wasting my time? Link to comment Share on other sites More sharing options...
urfsin Posted July 11, 2013 Share Posted July 11, 2013 Lot's of people have boosted N/A Subie's with mixed results. It seems that you are OK if you don't push it too much, say 6psi and below. Slide It Sideways Link to comment Share on other sites More sharing options...
whitetiger Posted July 11, 2013 Share Posted July 11, 2013 most do turbos because there is a larger knowledge base for it. Not sure what you plan to spend, but you can probably find a wrecked 02-05 wrx and do a motor swap for the same as a new turbo/sc install and you'd end up being more reliable for it. there are over 10 years worth of turbo subaru donors out there that can be had for cheap. Link to comment Share on other sites More sharing options...
monkeyposeur Posted July 12, 2013 Share Posted July 12, 2013 Reddevil on NASIOC has supercharged a leggy, as well as a few others. It seems like a lot more work than doing a swap and takes a lot of skill. Its more of an uncharted territory than a turbo swap. If you want a linear power curve consider an H6 swap. It's not recommended to boost the 2.5 which is what you have. You'd be better off boosting a 22E. You have a lot of options. Link to comment Share on other sites More sharing options...
Zues Marine Posted July 15, 2013 Share Posted July 15, 2013 anothernord on sl-i has done it as well Link to comment Share on other sites More sharing options...
Jacobpockros Posted July 21, 2013 Share Posted July 21, 2013 Eaton ftw: http://legacygt.com/forums/attachment.php?attachmentid=156764&d=1373146346 [ame=http://www.youtube.com/watch?v=6nvzz6wZPEg]'00 subaru legacy gt, ej205 swapped w/eaton m62 SC - YouTube[/ame] http://legacygt.com/forums/showthread.php/ej205-00-lgtli-project-build-thread-190422.html Link to comment Share on other sites More sharing options...
scoobydoo73 Posted July 27, 2013 Share Posted July 27, 2013 I'm pretty sure they used enough rubber to make a set of tires to make a belt that big. Link to comment Share on other sites More sharing options...
kred Posted July 27, 2013 Share Posted July 27, 2013 I was just thinking of this idea myself last night. The whole concept of a supercharged N/A legacy seems so much simpler than going turbocharged. I would get rid of my AC for a supercharger in a heart beat. I bet if you wanted to, you could piece a supercharger setup together for under a grand realistically plus tuning. Or save yourself the hassle and buy a kit for 3-4k. Link to comment Share on other sites More sharing options...
bomberlegacy Posted July 27, 2013 Share Posted July 27, 2013 OP.. what is your budget for this? '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
2point5GT_Dan Posted July 31, 2013 Share Posted July 31, 2013 This is one of those projects where if you have to ask how to do it you shouldn't be doing it. The EJ25D sucks anyways. boost a 2.2 or swap a turbo motor or H6 Link to comment Share on other sites More sharing options...
