06 OBXT brake upgrade questions.
Rester5350
I know this is a fairly common swap but i have not been able to find the answer to these questions. I do have a set of mostly complete lgt rear knuckles. ( they are pretty rusty )
1. Will my OB parking brake work with the lgt rear rotors ?
2. Are the lgt rear knuckles the same as my OB?
3. If the answer to #2 is yes, than is worth while to swap the whole knuckle with lgt parking brake?
4. If I swap the rk what bushings should I replace.
5. Should I take a wire wheel to them and clean them up?
6. If yes to #5 what should I do to prohibit rust?
