chazb22 Posted December 16, 2009 Share Posted December 16, 2009 I've got a 05 legacy gt currently 325whp 317tq. Would appreciate any advice on the perfect setup to obtain 500whp. So I can beat the shit out of it without worrying if I'm going to blow it up. Link to comment Share on other sites More sharing options...
whitetiger Posted December 16, 2009 Share Posted December 16, 2009 you will need a fully built motor and trans and a large rotated turbo setup. got an extra $20k sitting around? Link to comment Share on other sites More sharing options...
chazb22 Posted December 16, 2009 Author Share Posted December 16, 2009 LOL if I started over I would. Wish I did my research first. Just spent money on what I found early. Not much was available. When I got it. Currently running Superzilla 20g Perrin tmic fuel rails 650cc Dw inectors Cobb intake Skunk greedy evo 2 exhaust Ividia up and down pipe Hks unequal headers Tein monoflex coilover suspension with edfc Rotura brake kit 4 piston fronts 2 piston rear drilled and slotted rotors 2 piece Volk racing 18 x 8.5 rims wrapped with brigestone potenza tires Complete jl audio stereo components and sub with 7 inch pioneer DVD in dash navigation completely dynomatted Tuned by Automaster. Amr of mamaroneck ny Link to comment Share on other sites More sharing options...
Chocoholic005 Posted December 17, 2009 Share Posted December 17, 2009 Neither the transmission nor the motor is going to be able to handle those numbers. So before you start building a turbo setup for that power goal you're gonna need to think about how you wanna build your motor to handle it. A simple rebuild with upgraded rods and forged pistons would probably handle it for a while, but maybe not for the long hall. You'll wanna do alot of research for that... Next come the trans. PPG gears may handle 500, but I wouldn't risk it, I'd just upgrade to the 6 speed to be safe. Link to comment Share on other sites More sharing options...
mercury3545 Posted December 17, 2009 Share Posted December 17, 2009 How about some pictures? Link to comment Share on other sites More sharing options...
ShockerGT Posted December 17, 2009 Share Posted December 17, 2009 I've got a 05 legacy gt currently 325whp 317tq. Would appreciate any advice on the perfect setup to obtain 500whp. So I can beat the shit out of it without worrying if I'm going to blow it up. A ton of money. Link to comment Share on other sites More sharing options...
joeleodee Posted December 17, 2009 Share Posted December 17, 2009 A ton of money. +1 A Cosworth built motor or something comparable running well into 5 digits. You also have to think about that gear box. Then a rotated kit. I don't know if $20k would be enough , unless of course you buy it all used. Then you gotta worry about what that guy did with the stuff before you and if that'll cause a premature catastrophic failure. If you tell us what kind of money you are willing to spend, folks here will tell you if that's attainable. Actually, my opinion would be to put your car back to stock, sell your parts here, then sell your car and buy something that'll give you that 500whp. It will be much cheaper in the long run especially since an already built car can never sell for the amount of money and time put into it. If you wait long enough, there may be a Legacy GT putting those kind of numbers down that shows up in the Classifieds here. You never know. Link to comment Share on other sites More sharing options...
Aczwild Posted December 17, 2009 Share Posted December 17, 2009 .... http://legacygt.com/forums/showthread.php?t=103626&highlight=groff ... 550 JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
loserpro2 Posted December 17, 2009 Share Posted December 17, 2009 didn't farmerjohn i think make a 500hp leggy as well? but very sadly totalled it. Link to comment Share on other sites More sharing options...
mightyS Posted December 17, 2009 Share Posted December 17, 2009 Why do you want so much power? I had my 05 street tuned by a Cobb protuner and it has more than enough power. I've raced it several times in autocrosses and never thought it needed more. Even with stock hp, the Legacy GT did well in the Koni challenge races. Link to comment Share on other sites More sharing options...
05pearl Posted December 17, 2009 Share Posted December 17, 2009 Go back to stock and keep all the supporting mods that you can use. Sell or trade your 05 for a used spec B w/ 6 speed trans. Build the engine, get a rotated turbo set up w/ the power curve you want and your good to go. Link to comment Share on other sites More sharing options...
wichitalegacy Posted December 17, 2009 Share Posted December 17, 2009 Just put a rotated 30 or 35 r on your car with supporting mods . Have fun . Thats what I did !!! drove the car for a while after that 392whp on pump and 514whp on race gas . You really don't need over 400 for a daily driver . I never had any problems with my tranny . Now clutches are another issue . I've been out of the lgt loop for a while now so I don't know who makes the best clutch. When I first started rps was the only option . I'd run it down the drag strip on redline in every gear cause the clutch would slip so bad . Good luck !!!! Link to comment Share on other sites More sharing options...
mustangendsley Posted December 17, 2009 Share Posted December 17, 2009 WHY? 325 is plenty for this car. 500 hp is just dumb, you can't handle it, only in a straight line. Link to comment Share on other sites More sharing options...
subie_dude05 Posted December 17, 2009 Share Posted December 17, 2009 There ya go...... or like the others said a good stash of money. and can i have some? http://img.photobucket.com/albums/v192/elishafire/Lamborghini-Gallardo-001.jpg Link to comment Share on other sites More sharing options...
blaze165 Posted December 18, 2009 Share Posted December 18, 2009 Just put a rotated 30 or 35 r on your car with supporting mods . Have fun . Thats what I did !!! drove the car for a while after that 392whp on pump and 514whp on race gas . You really don't need over 400 for a daily driver . I never had any problems with my tranny . Now clutches are another issue . I've been out of the lgt loop for a while now so I don't know who makes the best clutch. When I first started rps was the only option . I'd run it down the drag strip on redline in every gear cause the clutch would slip so bad . Good luck !!!! your transmission held that? damn thats surprising Link to comment Share on other sites More sharing options...
05pearl Posted December 18, 2009 Share Posted December 18, 2009 your transmission held that? damn thats surprising He probably did not drive abusively. And, I doubt he ran race gas in his DD. I think his pump gas tune was under 400whp and the larger turbos spool slower so it may not have shocked the trans so much if not driven abusively. Link to comment Share on other sites More sharing options...
Belo Posted December 18, 2009 Share Posted December 18, 2009 I'm new to the lgt, but not cars. For what you're looking to do and what it'll cost you I think you're better off buying a different car. Link to comment Share on other sites More sharing options...
johnAWD Posted December 18, 2009 Share Posted December 18, 2009 If you have a few big bags of $$ to drop into the car: 1) built motor 2) gt30 or gt35 and supporting mods 3) tune tune tune 4) keep a good supply of spare clutches around Link to comment Share on other sites More sharing options...
05stilegacy Posted November 17, 2018 Share Posted November 17, 2018 To make 500 wheel you will need to do the same thing anyone would need to do as if they had a wrx or sti. I ran the stock block with forged internals for a while on a big borg Warner rotated. I had the best of everything. I cracked a piston. Lol. I now rebuild it with a closed deck built shortblock and make 560wheel on 28psi. Bigger turbos make more power on less boost. You will need bigger fuel system, built block. Bigger turbo. And a custom rotated kit that’s done right. I’m also running pump gas with methanol Link to comment Share on other sites More sharing options...
05stilegacy Posted November 17, 2018 Share Posted November 17, 2018 Oh yea I have the 6speed sti tranny as well Link to comment Share on other sites More sharing options...
relative4 Posted November 17, 2018 Share Posted November 17, 2018 Link to comment Share on other sites More sharing options...
boxkita Posted November 18, 2018 Share Posted November 18, 2018 Gotta get your post count up fast. Dead threads are best. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
05stilegacy Posted November 18, 2018 Share Posted November 18, 2018 Lol I’d like to start a 500whp thread back up, not too many ppl have 500whp legacys Link to comment Share on other sites More sharing options...
boxkita Posted November 18, 2018 Share Posted November 18, 2018 Lol I’d like to start a 500whp thread back up, not too many ppl have 500whp legacys Probably for a good reason or 3 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
05stilegacy Posted November 20, 2018 Share Posted November 20, 2018 Well because not too many people have a legacy like that. Mines for sale right now, brand new build Link to comment Share on other sites More sharing options...
