cdthomer Posted April 4, 2018 Share Posted April 4, 2018 Howdy folks...it turns out that clunking wasn't just my CV axles, but is indeed my center diff. So I'm going to replace it along with the three bearings on the transfer drive and transfer driven gears. Obviously this entails flushing the tranny fluid so I'm going to do the rear diff fluid as well just to have everything with fresh fluid. My question is what else should I replace while I'm under there? It seems like this a pretty standalone project but I wanted to doublecheck to see if there's anything I'm missing. If anybody else here has done this let me know any tips you might have. Thanks in advance! Link to comment Share on other sites More sharing options...
apexi Posted April 5, 2018 Share Posted April 5, 2018 Here were my thoughts after doing the job, that thread also has other info on doing the job, you might have already seen it. http://legacygt.com/forums/showpost.php?p=5425477&postcount=70 I'd just recommend things that might be obvious to some people.. New exhaust springs/bolts if yours are old, maybe a new donut gasket for the exhaust too. I can't remember if I dropped the exhaust towards the front of the car, with the 3 studs and triangular gasket. So one more gasket it might not be a bad idea to replace, but I can't remember if you have to disconnect the exhaust there. I used permatex gear oil rtv instead of regular rtv, seems like a good idea to go with that over regular rtv. Buy a punch set if you don't already have one for the shifter linkage roll pins. I say pins because there is a small roll pin inside of the big roll pin. I forget what size punch I used to remove them. Link to comment Share on other sites More sharing options...
cdthomer Posted April 5, 2018 Author Share Posted April 5, 2018 Here were my thoughts after doing the job, that thread also has other info on doing the job, you might have already seen it. http://legacygt.com/forums/showpost.php?p=5425477&postcount=70 I'd just recommend things that might be obvious to some people.. New exhaust springs/bolts if yours are old, maybe a new donut gasket for the exhaust too. I can't remember if I dropped the exhaust towards the front of the car, with the 3 studs and triangular gasket. So one more gasket it might not be a bad idea to replace, but I can't remember if you have to disconnect the exhaust there. I used permatex gear oil rtv instead of regular rtv, seems like a good idea to go with that over regular rtv. Buy a punch set if you don't already have one for the shifter linkage roll pins. I say pins because there is a small roll pin inside of the big roll pin. I forget what size punch I used to remove them. Haha I found that thread and bookmarked it. I also used it as a preliminary parts list. Thanks for your tips. So you didn't use a regular gasket? Just the rtv? Link to comment Share on other sites More sharing options...
Wasted Potential Posted April 5, 2018 Share Posted April 5, 2018 Any rust on the vehicle? Check the gas tank seams! I mean the driveshaft is the easiest part and you're only 10% of the way there to dropping the rear diff and subframe... But while you're at it might as well do the fuel pump.... And the injectors.... And the turbo.... Long block.... Crap... How did I end up here? Link to comment Share on other sites More sharing options...
whitetiger Posted April 5, 2018 Share Posted April 5, 2018 center diff upgrade time - http://www.ppgearbox.com.au/page.asp?productid=73 Link to comment Share on other sites More sharing options...
cdthomer Posted April 5, 2018 Author Share Posted April 5, 2018 Any rust on the vehicle? Check the gas tank seams! I mean the driveshaft is the easiest part and you're only 10% of the way there to dropping the rear diff and subframe... But while you're at it might as well do the fuel pump.... And the injectors.... And the turbo.... Long block.... Crap... How did I end up here? Haha thanks but mine's not a GT so no turbos for me Link to comment Share on other sites More sharing options...
cdthomer Posted April 5, 2018 Author Share Posted April 5, 2018 center diff upgrade time - http://www.ppgearbox.com.au/page.asp?productid=73 Haha don't think my non-turbo would benefit much from that upgrade Link to comment Share on other sites More sharing options...
apexi Posted April 5, 2018 Share Posted April 5, 2018 As far as I know there is no gasket, I didn't see one at parts.subaru.com, and the FSM calls for a specific kind of threebond RTV. I wish there was a gasket, that way I wouldn't have had to wait 24 hours for the rtv to fully cure before refilling my transmission with gear oil. You might not have to wait that long, I'd imagine dealerships don't wait that long, but I did anyway. Link to comment Share on other sites More sharing options...
