ICE7 Posted June 18, 2019 Share Posted June 18, 2019 Guys, Does anyone knows the size of the injectors on the 2.5 GT Legacy. I've also attached a picture of my current / stock injectors....however, i can't find out what's it size / cc. Regards, Brian Link to comment Share on other sites More sharing options...
Fabsx Posted June 18, 2019 Share Posted June 18, 2019 Guys, Does anyone knows the size of the injectors on the 2.5 GT Legacy. I've also attached a picture of my current / stock injectors....however, i can't find out what's it size / cc. Regards, Brian Whatever those injectors are, they are not the stock ones. From my gathering and research, those seem to be the stock cc flow, but a ebay/amazon brand. Non denso oem brand I’m guessing your having issues with them? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
ICE7 Posted June 19, 2019 Author Share Posted June 19, 2019 Whatever those injectors are, they are not the stock ones. From my gathering and research, those seem to be the stock cc flow, but a ebay/amazon brand. Non denso oem brand I’m guessing your having issues with them? Sent from my iPhone using Tapatalk Thanks for the response. But actually it is the Original Denso Injectors. It's working fine...however, I don't know the size / cc flow and as such I would like to know for future upgrades if need be. It is marked Denso on the other side. Thanks for the reply bro. Link to comment Share on other sites More sharing options...
ICE7 Posted June 19, 2019 Author Share Posted June 19, 2019 Whatever those injectors are, they are not the stock ones. From my gathering and research, those seem to be the stock cc flow, but a ebay/amazon brand. Non denso oem brand I’m guessing your having issues with them? Sent from my iPhone using Tapatalk Here it is Denso...but i do agree, on Amazon you're not seeing the Denso Green Injector??? hmmm Link to comment Share on other sites More sharing options...
Fabsx Posted June 19, 2019 Share Posted June 19, 2019 Here it is Denso...but i do agree, on Amazon you're not seeing the Denso Green Injector??? hmmm If your Gt is not tuned and completely stock. You can most certainly know that those are stock size CC injectors then. Anything else will result in a completely poor running car. You have the turbo model or NA? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
ICE7 Posted June 22, 2019 Author Share Posted June 22, 2019 If your Gt is not tuned and completely stock. You can most certainly know that those are stock size CC injectors then. Anything else will result in a completely poor running car. You have the turbo model or NA? Sent from my iPhone using Tapatalk It is a Turbo vehicle (2.5GT)...and yes i do believe that the engine is stock. So with that in mind, I would tend to lead on the side of the Injectors being 550's. But, I just wish that i had some sort of conformation on that...rather than guesstimating. Regards, Brian Link to comment Share on other sites More sharing options...
Fabsx Posted June 22, 2019 Share Posted June 22, 2019 Stock car.. stock injectors. No guessing here. Get some stock oem denso ones and see if they’ll run good. That’ll answer your question. Or find someone locally and take a peak at your map and see if it’s been opensourced. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
ICE7 Posted June 22, 2019 Author Share Posted June 22, 2019 Stock car.. stock injectors. No guessing here. Get some stock oem denso ones and see if they’ll run good. That’ll answer your question. Or find someone locally and take a peak at your map and see if it’s been opensourced. Sent from my iPhone using Tapatalk Thanks....Will keep you posted bro. regards, Brian Link to comment Share on other sites More sharing options...
Deadrick20 Posted June 26, 2019 Share Posted June 26, 2019 Weird. My stock injectors were blue. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
moral hazard Posted June 26, 2019 Share Posted June 26, 2019 (edited) These are stock injectors (same as the ones that came on my 2010 AUDM 5eat GT). They are 525cc (you can actually open your stock rom in ECUflash or romraider and read the stock injectors scaler value to see this). Edited June 26, 2019 by moral hazard Link to comment Share on other sites More sharing options...
Register a new accountSign in
