Stevethecat Posted February 13, 2018 Share Posted February 13, 2018 So my car started missfiring after a few hours of running errands. The car was warm and then say for maybe ten minutes. I restarted the car and it immediately had a very obvious misfire. I read the code as a cylinder 3 misfire. After getting the car home i tested the spark plug by swapping between 1 and 3 and the same for the coils. Then ran a compression test and everything looked okay, but the misfire stayed with cylinder three. This morning after the car had sat overnight I noticed the car runs much better cold. I only drove it around the block a few times. But i noticed that as is warms up there is almost no power from a dead stop, but it gains power as the rpms rise. After pulling back into the garage i started to tackle the fuel injectors and notice right away that cylinder three has a crack on the top of the injector. I intent to fix this. My question is, do these symptoms sound like they would come from the bad injector or does this sound like a bigger problem. Also what would people recommend as a brand or source to buy a quality replacement I included two pictures. one of the cracked injector and the second of cylinder 1s injector without the crack. Link to comment Share on other sites More sharing options...
relative4 Posted February 13, 2018 Share Posted February 13, 2018 The grey circle on top (that's the crack you're referring to, right?) is a dustcap. Looks like maybe whoever installed it thought they could push on it. Crack in dustcap + time = ruined injector. I would never recommend replacing the injector without first swapping, but it sounds like you have a very strong candidate here. Sometimes reman injectors come without a dustcap, so make sure your replacement comes with one. Link to comment Share on other sites More sharing options...
stocklgt Posted February 13, 2018 Share Posted February 13, 2018 swap injectors between cylinders and see if the misfire follows the injector. if not its another issue. When I cleaned my injectors the problem came back but in a different cylinder. I switched the cylinders the injectors were in and the miss followed the injector, so after checking we determined it was the electrical connector on one of the injectors. Unfortunately cleaning them did not solve my issue, but I was going with bigger injectors anyway so it wasnt a huge deal. Link to comment Share on other sites More sharing options...
Stevethecat Posted February 14, 2018 Author Share Posted February 14, 2018 its definitely the dust cap i found a set of used ones for cheap so decided wth ill see how they go Link to comment Share on other sites More sharing options...
relative4 Posted February 14, 2018 Share Posted February 14, 2018 Sorry if I was unclear. Replacing the dustcap is not going to solve your problem. An intact dustcap might have prevented this problem from happening, depending on what the problem is, but if the injector is now bad, you will need to address that. Link to comment Share on other sites More sharing options...
Stevethecat Posted February 14, 2018 Author Share Posted February 14, 2018 oh lol i meant i found someone selling a set of injectors not just the dust caps Link to comment Share on other sites More sharing options...
wpmarky Posted February 14, 2018 Share Posted February 14, 2018 I have oem injectors (used) if you need 1 or more Link to comment Share on other sites More sharing options...
Stevethecat Posted February 17, 2018 Author Share Posted February 17, 2018 Just got the replacement injector installed and shes back to 100%. No more signs of a missfire Link to comment Share on other sites More sharing options...
JmP6889928 Posted February 20, 2018 Share Posted February 20, 2018 Good job. You did the work and diagnosed it down to the root problem and then fixed it and didn't throw your hands up and expect someone else to do it for you. Bravo! Link to comment Share on other sites More sharing options...
Stevethecat Posted February 20, 2018 Author Share Posted February 20, 2018 Ha thanks, I did have plenty of help from the archives here and from the community for helping me get a cheap injector so quickly. It does feel good to get it done with out having to call people. When your baby stops running it can get pretty stressful Link to comment Share on other sites More sharing options...
