I Donated thefultonhow Posted March 11, 2013 I Donated Share Posted March 11, 2013 I'm trying to get the engine separated from the transmission, but I can't get them separated more than half an inch to an inch. Anything I might be missing? Some details: - All bellhousing bolts are out, and I managed to pop out the pins that hold the engine and trans together. - DP is off. - Turbo is still on. I can't get the bottom coolant line off, so I figured I'd do that out of the car. But the turbo is unbolted, so there is a little bit of movement. - The straps that I've connected to the engine hoist don't seem to be caught on anything. - Accessories are off the engine (and the accessory harness along with it). - All mounts have been unbolted. - The main electrical connector, the front O2 connector, and the grounding straps are undone. Help! It wasn't nearly this hard to get the engine out of my 05... Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted March 11, 2013 I Donated Too Share Posted March 11, 2013 Clutch fork? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 11, 2013 Share Posted March 11, 2013 You did the fuel lines right ? It should come off the tranny more then 1 inch before you try and lift it. Your hung up on the input shaft and the clutch. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Underdog Posted March 11, 2013 Share Posted March 11, 2013 The flange on the turbo for the DP connection can get caught on a corner of the transmission bell housing. Fuel lines are disconnected, right? The Crimson Dynamo Link to comment Share on other sites More sharing options...
Max Capacity Posted March 11, 2013 Share Posted March 11, 2013 Yes, make sure the slave cylinder if off and the dog bone. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted March 11, 2013 I Donated Too Share Posted March 11, 2013 make sure you pull the big pin from here as in this picture where it is no more! http://i193.photobucket.com/albums/z151/Legacy_NSFW/6MT/FlyingClutchFork.jpg Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted March 11, 2013 I Donated Too Share Posted March 11, 2013 http://i73.photobucket.com/albums/i219/lethaldose_2002/Scoobymods_Quick%20Loads/DSCN0255.jpg better pic - use same T70 Torx Bit as you would for gearbox oil... thread in a bolt, pull out the shaft. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 11, 2013 Share Posted March 11, 2013 Wish I could see the photo, I don't remember using a T-70 when I pulled my engine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted March 11, 2013 I Donated Too Share Posted March 11, 2013 Hmmm might just be a big hex head - now you making me think... Link to comment Share on other sites More sharing options...
Max Capacity Posted March 11, 2013 Share Posted March 11, 2013 Is that the dog bone your talking about ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted March 11, 2013 Share Posted March 11, 2013 Big hex... close enough tho Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 11, 2013 Author I Donated Share Posted March 11, 2013 make sure you pull the big pin from here as in this picture where it is no more! http://i193.photobucket.com/albums/z151/Legacy_NSFW/6MT/FlyingClutchFork.jpg Ding ding ding! We have a winner! I completely did not think about the fact that a pull-type clutch probably would be pretty well stuck together due to the design of the TOB. (My 05 was push-type.) I took out that pin (it wasn't easy) and managed to get everything apart. Now to get the flywheel to the machine shop before it closes for the day... Also, my clutch disk was pretty worn out. No wonder I got slippage sometimes! Link to comment Share on other sites More sharing options...
