STI parts for LGT
As some of you may know I'm parting out a 2011 STI sedan. Here are some parts I'm not keeping that should fit Legacies but do your own research to confirm. Everything listed has 100k miles (160k kms) and is in good working condition unless otherwise noted. All prices are OBO and do not include shipping:
These parts should be direct swap:
Fuel pump assembly/housing complete with STI pump (175lph vs LGT 150lph) $150
STI pitch stop $40
Alternator - $40 sold
Power steering pump - $40 sold
Steering rack - $100 (may be a lot to ship)
STI red stitched steering wheel. Direct swap for 07-09 legacy and can be retrofitted to 05-06 (has a couple of wear areas on the leather so selling cheap) - $40
LGT (blue Subaru emblem) horn pad with airbag (can be used to update 05-07 car to 08-09 style steering wheel) $60 sold locally
These parts can be used with modification:
All 4 STI 5x114.3 knuckles with hubs (if you want to do a very ambitious 6 speed swap) $200
Rear STI Brembo calipers for previously mentioned crazy swap $700 shipped (also direct bolt on for 5th gen models) Sold off-site
STI stock front/rear struts and springs that would work with that swap $200
Driveshaft also available $200
I'm also considering selling this bulkhead harness, STI gauge cluster, ECU, ignition ring, key as a combo + whatever else you can think of that is needed to overcome the immobilizer and challenges using a CANBUS 2011 STI ECU (in case you want to try and run a dual AVCS using this ECU - I do not). This would be expensive, (maybe $400+shipping?) and you would have to be a sadist. If interested let me know exactly what components you want/need and I will remove and sell them as a combo for you.
More pics to come
Edited by Shogun506
Do you have the steering ujoint linkage? Also I don't think I've ever seen/noticed anyone going for the sti steering pump. Are you saying they're interchangeable just by eyeballing it? I'm vaguely in need of a pump and my last two carquest remans are pretty whiny.
I'm keeping the steering linkage for use in my car. The PS pump looks to be the same and has all the same lines and dimensions so I can't imagine it would be any different between the 2 cars but can definitely send you more pics and part number if you like. I'm 90% sure it's a match though considering the PS reservoir and steering rack are swappable between the 2 cars.
Thanks and makes perfect sense. I'll pass on the ps pump for now. glws!
