mikec1 Posted January 17, 2022 Share Posted January 17, 2022 Just wondering if anyone has any insight to the noise I'm experiencing. Sounds like gravel/metal grinding on metal while driving. Has progressively gotten worse as it has gotten colder. Coming from right front side, only while under load and braking, cruising noise seems to disappear. Vid below (whining noise is a bad ground, can faintly hear the noise I describe) Any help is appreciated, thanks! Link to comment Share on other sites More sharing options...
Febreze Mee Posted January 17, 2022 Share Posted January 17, 2022 I couldn't make it out in the video. Regardless, someone's going to have to get in that right-front wheel well anyway. It's best to take an hour yourself, remove the wheel and visually inspect to see if you can see the problem, rather than pay someone else an hour's labor rate to do the same thing. Maybe worn out pads, down to the metal? A bad wheel bearing? When was the last time (date and mileage) you replaced/resurfaced the rotors? How about the pads? Have any of the calipers ever been replaced, if so when? Wheel bearing replacements? It could be something a simple as a rock making contact with the rotor - this happens to me on a monthly basis. Or it could be a little more involved such as replacing a tired wheel bearing. I've replaced 3x wheel bearing in the last year and half now. Both rears and a front. All gave the same characteristic you've described. Once the metal heats up, the whining isn't as violent. At cruising speeds it simmers. To check the bearing, jack up the car, and grab the tire at the 12 o'clock and 6 o'clock positions. Push with one hand while pulling with the other in a continuous back in forth motion. If there's a lot of play, you sir have a bad wheel bearing. If any of the above directions are confusing, refer to timestamp 1:43 here: MILKRUN - Click Here Link to comment Share on other sites More sharing options...
mikec1 Posted January 17, 2022 Author Share Posted January 17, 2022 I couldn't make it out in the video. Regardless, someone's going to have to get in that right-front wheel well anyway. It's best to take an hour yourself, remove the wheel and visually inspect to see if you can see the problem, rather than pay someone else an hour's labor rate to do the same thing. Maybe worn out pads, down to the metal? A bad wheel bearing? When was the last time (date and mileage) you replaced/resurfaced the rotors? How about the pads? Have any of the calipers ever been replaced, if so when? Wheel bearing replacements? It could be something a simple as a rock making contact with the rotor - this happens to me on a monthly basis. Or it could be a little more involved such as replacing a tired wheel bearing. I've replaced 3x wheel bearing in the last year and half now. Both rears and a front. All gave the same characteristic you've described. Once the metal heats up, the whining isn't as violent. At cruising speeds it simmers. To check the bearing, jack up the car, and grab the tire at the 12 o'clock and 6 o'clock positions. Push with one hand while pulling with the other in a continuous back in forth motion. If there's a lot of play, you sir have a bad wheel bearing. If any of the above directions are confusing, refer to timestamp 1:43 here: Recorded a new video while coasting in neutral, noise is a lot more apparent. Link to comment Share on other sites More sharing options...
silverton Posted January 18, 2022 Share Posted January 18, 2022 i hear... frozen snow on windshield wipers, and tires driving over snow. it's impossible to diag with a video dude. Link to comment Share on other sites More sharing options...
Pleides Posted January 19, 2022 Share Posted January 19, 2022 (edited) Have you checked to see if a heat shield or aero piece is dragging on the ground? I can't hear anything in the videos you linked either. Edited January 19, 2022 by Pleides Link to comment Share on other sites More sharing options...
