gkinslow Posted April 20, 2016 Share Posted April 20, 2016 Not looking to AutoX or anything so no serious fender mods planned. 235/40/18 shouldn't even require a roll? Or am I wrong? Putting on my kw coilovers at the same time and I'm not trying to be "slammed" or anything just eliminate %90 of the wheel gap. Link to comment Share on other sites More sharing options...
LatentWagen Posted April 20, 2016 Share Posted April 20, 2016 Depending on your camber, and ride height of course, you should be alright without a roll. Especially with the relatively skinny PSS's. Double check if you want to run DZII's or other fatties... tires of the same size can vary like an inch! LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
iNfEk Posted May 6, 2016 Share Posted May 6, 2016 been meaning to post this. I keep forgetting LOL Link to comment Share on other sites More sharing options...
fotofan Posted May 6, 2016 Share Posted May 6, 2016 I like that a lot! I put something here like all the cool people, except there's nothing cool to put here. Link to comment Share on other sites More sharing options...
iNfEk Posted May 6, 2016 Share Posted May 6, 2016 It's going to go through a major change hopefully soon. Got a bunch of stuff chilling on the side waiting for paint and to go on. Link to comment Share on other sites More sharing options...
LatentWagen Posted May 6, 2016 Share Posted May 6, 2016 I like that a lot! +1 It's going to go through a major change hopefully soon. Got a bunch of stuff chilling on the side waiting for paint and to go on. Those wheels look great on OBP! Alignment specs? Any plans for more camber? LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
iNfEk Posted May 6, 2016 Share Posted May 6, 2016 +1 Those wheels look great on OBP! Alignment specs? Any plans for more camber? Thanks! these are 18x9.5 +35 245/40 I believe. I'm on a stock-ish alignment right now. I plan to add some camber in the rear via a white line kit but not much. the edge of the tires are hitting the dog leg caps on the front side of the wheel when i have my kids in the back seat and we hit a bump that requires a little bit of suspension travel. I think I've got 1 degree on the top hat on the front i believe. I've got aluminum LCAs, BC coilers and kartboy end links. i'll be working the suspension a bit more as soon as i get a chance to work on my STI LOL Link to comment Share on other sites More sharing options...
gkinslow Posted May 6, 2016 Share Posted May 6, 2016 http://uploads.tapatalk-cdn.com/20160506/9ccaaffd65d22aff1ec50e1d31db66d2.jpg Link to comment Share on other sites More sharing options...
boxkita Posted May 9, 2016 Share Posted May 9, 2016 Looking to put the largest tire possible on my 09 LGT. Just bought a set of 18x8 +45 rims. Was hoping to fit a 235/45/18 without rolling the fenders or slight roll if necessary. Anyone running with these specs or really close?? Tires are $265 (michelin Pilot super sports) each and I want to verify fitment if possible before dropping that coin. 225/40/18 on 18x8 with super sports is a phenomenal combination. I went thru 2 sets with that combo and loved them. Stepping up to 235 on a 8 inch rim will not be as sticky or fun as you'll have more rollover which translates into sloppier handling. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
gkinslow Posted May 9, 2016 Share Posted May 9, 2016 225/40/18 on 18x8 with super sports is a phenomenal combination. I went thru 2 sets with that combo and loved them. Stepping up to 235 on a 8 inch rim will not be as sticky or fun as you'll have more rollover which translates into sloppier handling. Its too late now as the 235/40/18 are already in use. I do appreciate the info and personal experience Boxkita. This car sees plenty of spirited driving but zero autocross action, so hopefully the difference in handling won't be that noticeable...? I actually found a bend in one of my factory rims after removal. Hoping to avoid that with the new rims. Link to comment Share on other sites More sharing options...
iNfEk Posted May 23, 2016 Share Posted May 23, 2016 sigh. i swear i need to find the time to take proper photos of this car rather than at work in the parking lot LOL Link to comment Share on other sites More sharing options...
PimpFro Posted May 24, 2016 Share Posted May 24, 2016 245/35/18 on 8.5 wide wheels and a 48 mm offset, not sure if they are "meaty" but they stand exactly where I waneed them to. No poke, no sink in, flush, did have all 4 rolled just to be safe with the drop from the coils Pure Adrenaline Attached... To A License Plate Link to comment Share on other sites More sharing options...
adrenalinecrisis Posted May 3, 2017 Share Posted May 3, 2017 Thread revive? http://i.imgur.com/NNEa4lb.jpg First off, this is a sick setup. So much so that I have a set of those same rpf1's sitting in my basement waiting to be mounted . I see that you are on Koni's and swifts. What camber were you running? Did you have to roll all 4 corners? Pull the fenders at all? I'm running H&R's so I'm a little higher. Just trying to plan for what kinda work I'm gonna have to do to make them fit. Link to comment Share on other sites More sharing options...
JF1GG29 Posted May 4, 2017 Share Posted May 4, 2017 I think that is the finest fitment I've seen on an LGT, ever. Link to comment Share on other sites More sharing options...
needforsleep Posted May 25, 2017 Share Posted May 25, 2017 245/35/18 KDW's on 18x9 Volk TE37's from 4 years ago.. Now: 265/35/18 Pilot Super Sports on 18x9.5 Advan RZII's Link to comment Share on other sites More sharing options...
TheMonaLisa Posted September 30, 2017 Share Posted September 30, 2017 (edited) 245/40/18 Hankook V12 Evo2 on 18x8 et48 Edited September 30, 2017 by TheMonaLisa Link to comment Share on other sites More sharing options...
MPacMan15 Posted October 2, 2017 Share Posted October 2, 2017 255/35 on a 18x9.5 et38 Sent from my SAMSUNG-SM-G935A using Tapatalk Link to comment Share on other sites More sharing options...
bugeyemania Posted October 14, 2017 Share Posted October 14, 2017 255/35 on a 18x9.5 et38 Sent from my SAMSUNG-SM-G935A using Tapatalk How’s that fitment working out for you? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
MPacMan15 Posted October 17, 2017 Share Posted October 17, 2017 it's super tight, I have since lowered the car another 1/2in with very slight rubbing. It does take some camber to fit, I'm running -3.7 front and -3.2 rear Sent from my SAMSUNG-SM-G935A using Tapatalk Link to comment Share on other sites More sharing options...
LatentWagen Posted October 17, 2017 Share Posted October 17, 2017 It does take some camber to fit, I'm running -3.7 front and -3.2 rear "Some" LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
Rattsl Posted October 17, 2017 Share Posted October 17, 2017 That's not some. That's a lot. I don't even run that much camber. Link to comment Share on other sites More sharing options...
JohnnyWas Posted October 22, 2017 Share Posted October 22, 2017 it's super tight, I have since lowered the car another 1/2in with very slight rubbing. It does take some camber to fit, I'm running -3.7 front and -3.2 rear Sent from my SAMSUNG-SM-G935A using Tapatalk Never hated my stretch more than now!! Prepared to dial in more camber for better fitment / tread contact Link to comment Share on other sites More sharing options...
MPacMan15 Posted October 23, 2017 Share Posted October 23, 2017 here's the current ride height and rear fitment hahaha Sent from my SAMSUNG-SM-G935A using Tapatalk Link to comment Share on other sites More sharing options...
TheMonaLisa Posted October 28, 2017 Share Posted October 28, 2017 Anyone have pictures of Hoosiers on their Legacy? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
stocklgt Posted August 8, 2018 Share Posted August 8, 2018 Got my 255s on the 8.5" Weds and surprised to say there is little to no rub. On a big bump the rear catches a little, but surprised that i didn't need to pull! Link to comment Share on other sites More sharing options...
