LGTDriver Posted May 22, 2013 Share Posted May 22, 2013 The other day it rained fairly hard and obviously my legacy was parked outside. In the morning when I go to start it, it automatically throws a CEL with flashing Cruise. The whole nine yards. I drove it to school bc I had no option on how to gt to class but while driving It felt as if the car had limited power. I've noticed that when it rains or the weather is fairly humid, it tends to do this to me. BUT if I turn it on and off and couple of times It will run normally and the power is back. The check engine is still on though. I took It to my dads shop and threw the scanner at it and I got the P2012 Code. I have searched already and is couldn't find anything that helped. A couple of months ago I got the same thing after a heavy rain and it was the same code. I changed the TGV sensors and everything was fine. But now I guess it is back. The car runs fine, turbo kicks in properly and everything. I noticed that the Cover that is on the hood gets wet when it rains and It takes a while to dry. I live in Miami so this is car has never seen snow or any temp under 40 degrees F. Any advice or help would be great. Thanks! Link to comment Share on other sites More sharing options...
chimera Posted May 23, 2013 Share Posted May 23, 2013 P2012 is in range of TGV related codes, see: http://forums.sidc.co.uk/topic/159146-error-code-p2012/ And FAQ on tgv deletes http://forums.nasioc.com/forums/showthread.php?t=1663677 Link to comment Share on other sites More sharing options...
