valerka Posted July 23, 2010 Share Posted July 23, 2010 I just got my Tactrix 2.0 from Tactrix Inc. I have installed all the required software on my laptop including drivers and once connected for the first time to PC, nothing happened. So I thought that I might need to connect to the car in order for the cable to be recognized, well did it first thing this morning and nothing happened. Tried a few different cables and another PC and nothing helped, connecting the cable does not produce and response from the PC and nothing is flashing on the unit itself. Would that be a defective unit? Has any one else had problems from the get go and how good are Tactrix with their customer support? Link to comment Share on other sites More sharing options...
John M Posted July 23, 2010 Share Posted July 23, 2010 If you've tried the cable on several computers and none respond with the "found new hardware" dialog, it does sound like the cable is defective. Link to comment Share on other sites More sharing options...
valerka Posted July 23, 2010 Author Share Posted July 23, 2010 I am getting a bit of a trouble getting a hold of Tactrix. Anyone ever delt with their support? Link to comment Share on other sites More sharing options...
rtbrjason Posted July 25, 2010 Share Posted July 25, 2010 I would start over first. Uninstall anything you installed and reboot the pc. Install the latest version of ECUFlash. (I'm using the latest beta found here: http://www.tactrix.com/index.php?option=com_content&view=category&layout=blog&id=44&Itemid=65) Once the program is installed it should show 3 different drivers being installed after. The first time you plug into the car and turn the key to acc, it should find new hardware and install another driver. That should be it as far as connecting. If you're not getting to this point, then something else might be going on. Link to comment Share on other sites More sharing options...
valerka Posted July 26, 2010 Author Share Posted July 26, 2010 I have tried that, I also do see it installing the three initial drivers, once connecting to the vehicle it produces no response and no lights can be seen flashing. Again, I would expect to connect the cable to a PC, drivers/no drivers and it should at least advise me of finding new hardware, but it doesn't. So far after about 10+ calls to Tactrix, one voicemail and one email sent last Friday, I did not get a response to my problem. Will continue trying..... Link to comment Share on other sites More sharing options...
wpmarky Posted July 26, 2010 Share Posted July 26, 2010 Which operating system are you using? Link to comment Share on other sites More sharing options...
valerka Posted July 28, 2010 Author Share Posted July 28, 2010 Everything is fixed, as suspected the cable ended up being defective. Got a hold of Tactix on Monday and received my Cable today, Tuesday. Exceptional customer service!!! The new cable works like a charm and I off to do some logging! Once again top marks to Tactrix for handling the replacement. Link to comment Share on other sites More sharing options...
rock2534 Posted October 23, 2010 Share Posted October 23, 2010 I would start over first. Uninstall anything you installed and reboot the pc. Install the latest version of ECUFlash. (I'm using the latest beta found here: http://www.tactrix.com/index.php?option=com_content&view=category&layout=blog&id=44&Itemid=65) Once the program is installed it should show 3 different drivers being installed after. The first time you plug into the car and turn the key to acc, it should find new hardware and install another driver. That should be it as far as connecting. If you're not getting to this point, then something else might be going on. I am not getting that 3rd install once the car is turned on, it appears to try and read the ecu, but fails not too long after stating "interface closed" Link to comment Share on other sites More sharing options...
