phish27134 Posted October 15, 2019 Share Posted October 15, 2019 When removing the transmission from the engine without pulling the engine is it necessary to remove the clutch release shaft in order for the transmission to be broken loose from the engine? Link to comment Share on other sites More sharing options...
phish27134 Posted October 15, 2019 Author Share Posted October 15, 2019 (edited) In case anyone was wondering you do in fact need to remove the 14mm hex or 10mm hex to access the clutch release shaft. Then you need to thread a timing cover screw into the shaft to pull it out causing the fork to be moveable and push it towards the engine, then transmission will be freed. **Researched from an sti thread since info here is lacking on the 6MT Edited October 15, 2019 by phish27134 Sent too quick Link to comment Share on other sites More sharing options...
Max Capacity Posted October 18, 2019 Share Posted October 18, 2019 http://people.csail.mit.edu/ilh/vacation/ There's the service manual. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
phish27134 Posted October 21, 2019 Author Share Posted October 21, 2019 I saw that in the manual, but so many videos do not discuss this. I have a bigger problem, when i press the clutch it sticks to the floor, if I hold it however the car will start up? Throwout bearing not properly seated in the pressure plate? The slave was working before, its just that the fork doesn't want to seem to return. Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted November 27, 2019 Share Posted November 27, 2019 Yep exactly, I just dealt with that and ended up replacing the clutch. pull the intercooler off and try to get it to clip into the pressure plate manually. It's not holding in. If you were pulling on the engine while the fork was still attached you probably bent something and it won't grab anymore. 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
phish27134 Posted November 28, 2019 Author Share Posted November 28, 2019 I put the throw out on backwards, I had been working on it a night after 8 hour days, finally got the trans split, it was mid night, did everything properly cleaned bell housing, grease etc. attached new clutch pressure plate checked instructions multiple times but remember multiple nights prior gettin 2-4 hrs of sleep then 8 at a desk. Your bound to make a mistake, i had a borescope but lost it so i would have been able to tell, because i remember reading once you get it push the fork toward the engine to engage a sound should be heard, don't recall any of this happening, get it all back together, clutch pedal sinks as does my heart and this being my first time doing a clutch, i'm not noob but not an expert and way more familiar with my imprezas subaru specialist mechanic up..... At Least I now know how to do it properly, what to look for and more than willing to attempt again, although it seemed like an original clutch and now has a stage 1 exedy. Timing belt is approaching, I've done SOHC on my impreza, seen some vids on this engine and will not be taking the cheap route everything is getting replaced. Link to comment Share on other sites More sharing options...
phish27134 Posted November 28, 2019 Author Share Posted November 28, 2019 Question for ya, whats the condition of your dash? Link to comment Share on other sites More sharing options...
