thejazzcat Posted June 28, 2017 Share Posted June 28, 2017 I have my eyes set on the Borla exhaust for my 05 LGT, I love the Borla sound. I read that our stock pipe diameter is 2.5 to the y, which is the same size as the Borla piping for that section of pipe. Given the same diameters, is there any reason why I should go with the full catback vs an axleback version? Does the Borla center pipe have a feature or design that the stock piping doesn't? -thejazzcat Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Rhitter Posted June 28, 2017 Share Posted June 28, 2017 The Borla catback does not have the OEM resonator. Don't remember if it has any, and will be louder than just the axle back. My OBXT build Link to comment Share on other sites More sharing options...
MilesA Posted June 28, 2017 Share Posted June 28, 2017 Having the resonator is good, helps avoid drone. I would not get rid of it. Link to comment Share on other sites More sharing options...
The 2Fiver Posted June 28, 2017 Share Posted June 28, 2017 Given the same diameters, is there any reason why I should go with the full catback vs an axleback version? Does the Borla center pipe have a feature or design that the stock piping doesn't? The Borla catback system uses a slip-joint and clamp type setup. I don't know if they have an axelback option for mating up to the stock midpipe. It is only with a 3" downpipe that drone becomes an issue (for most) Link to comment Share on other sites More sharing options...
rapture Posted June 29, 2017 Share Posted June 29, 2017 I has the borla full catback Def has resinator I modified after few years , cut it out went straight pipe No drone either way , i think it sounds great either way Only other catback id go with would be invidia Also i went w invidia vcatless dwn, perrin bigtube up/ headers Perrin shortram cai, tgv deletes Upgraded all bushings and mounts Link to comment Share on other sites More sharing options...
thejazzcat Posted June 30, 2017 Author Share Posted June 30, 2017 The Borla catback system uses a slip-joint and clamp type setup. I don't know if they have an axelback option for mating up to the stock midpipe. It is only with a 3" downpipe that drone becomes an issue (for most) So what I think I am getting here is the resonator is the key difference between the Borla cat midpipe and the stocker, and that downpipe size matters as far as whether the resonator should remain or not? My downpipe choice to pair would be a grimmspeed, so that sounds like I would proabaly want to at least start with the resonator on to avoid drone since that's a full 3" downpipe? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
The 2Fiver Posted July 1, 2017 Share Posted July 1, 2017 So what I think I am getting here is the resonator is the key difference between the Borla cat midpipe and the stocker, and that downpipe size matters as far as whether the resonator should remain or not? My downpipe choice to pair would be a grimmspeed, so that sounds like I would proabaly want to at least start with the resonator on to avoid drone since that's a full 3" downpipe? Apparently Borla is the quietest, it'll probably sound great with an aftermarket downpipe. Don't cut out the resonator, it's an expensive catback system and holds value well if kept original. Link to comment Share on other sites More sharing options...
rapture Posted July 2, 2017 Share Posted July 2, 2017 The invidia is full 3" I still opted to remove my resonator Try it if you want you can always change it Link to comment Share on other sites More sharing options...
GEE-OTTO Posted August 4, 2017 Share Posted August 4, 2017 Apparently Borla is the quietest, it'll probably sound great with an aftermarket downpipe. Don't cut out the resonator, it's an expensive catback system and holds value well if kept original. Maybe the older style Borla didnt have that b/c round one with my other LGT i had a Borla and the Y pipe didnt have a resonator it was horrible on the highway (drone wise) but I could have added a XR1 resonator to clean that up except I found a Bosal v1.5. Link to comment Share on other sites More sharing options...
The 2Fiver Posted August 6, 2017 Share Posted August 6, 2017 I did'nt find highway driving so bad with a 3" catback, but going a up a steeper slope at low speed was painfully loud sometimes. Link to comment Share on other sites More sharing options...
thejazzcat Posted August 30, 2017 Author Share Posted August 30, 2017 Thanks for the input everyone, I went ahead with the Borla S-Type [emoji91][emoji13][emoji91]: Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
