Hella 70W or Nokya 65W H7 bulbs?
I've had mixed results with Nokya bulbs.
My H1 low beams in a 2002 Outback didn't last long at all. My 9006 fog lights are 10 years old. Not sure if I'll use them in lows again.
I am using the German Volsla 65W bulb from Daniel Stern Lighting that Grovlet stated above and I don't think it gets much better than those for halogen bulbs.
If you want something better, do an HID retrofit.
If you want your bulb life to last, disable your DRLs. They cut your bulb life in half.
MILKRUN  - Click Here
How much of a project is it to kill the DRLs?
Sent from my moto z3 using Tapatalk
Easy, put a blown fuse in it's place, easy to fix for any inspection and if you're pulled over for it well you can show that it wasn't "purposefully disabled"
08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy
Agreed, 65W bulbs are only marginally better than stock, that's why I feel like experimenting with cheaper 65W
Indeed disabled DRL, they are not mandated in my area and the 65W have shorter life span than 55W in general.
Edited by leetdrv
  • 2 weeks later...
The DRLs are your lowbeams. They reside behind your projector housing. Your DRLs operate at a reduced output when compared to you turn your lowbeams (light used when night-driving) on. I haven't a clue how much but, it's noticeable.
Your highbeam is a completely separate bulb located in the reflector housing.
In all, you have three bulbs in your headlight housing:
1) DRLs = lowbeams bulbs (at reduced power)
2) Highbeams/"brights"
3) Turn signals/"blinkers"
I am looking to disable my DRL's. Deciding on a course of action to do so. 2009 LGT sedan.
From what I had found in research:
2005-06: unplug white connector from DRL box in the driver footwell
2007: Cut wire
2008-09: unplug white connector from DRL box in the driver footwell
Doesn't hurt to check, I think you should have a DRL box behind that little trim panel on the left side of the driver footwell.
  • 2 years later...
Reporting back after 2 years.
The bulbs are still in the car. They put out more light than stock bulbs. The difference is not huge but it's apparent.
At $10/each, they are cheaper than anything I could get locally. I will buy these again unless I find something better for similar price.
Edited by leetdrv
