wastinglight Posted June 20, 2013 Share Posted June 20, 2013 ok guys im calling out to you in my time of need.i have a 1994 leagacy wagon FWD and last night my passenger side rear strut completely blew out so no i NEED to put my new ones in. i already have stock replacement KYB GR2 struts and would like to put a stiffer spring on. reading the other thread here i came to the conclusion that i can use 02-03 WRX springs with no modification, is this correct? also i think im going to change out the top mounts, if i go with a WRX spring which ones should i get? all help is greatly appreciated, and i have read the stickies but its a bit difficult to follow and i want to be absolutely sure before i buy the springs. thanks Link to comment Share on other sites More sharing options...
idiot4hire Posted June 20, 2013 Share Posted June 20, 2013 Can't be certain but I would think to reuse the factory ones with your car because your going to be using the oem replacement shock. Also I have wrx springs in my garage ill sell you Link to comment Share on other sites More sharing options...
