urdrwho Posted June 14, 2013 Share Posted June 14, 2013 I was just wondering why Subbies have two throttle cable cams. Is one so that the TPS can measure for the trans and one for the throttle opening angle?The reason I am asking is that today I plugged in my scan tool and pressed the pedal to the floor and the TPS never read 100%. I had to adjust the one cable to get it to read 100%.Also on my daily driver (not Subbie) the TPS should read .4 at closed throttle. I was reading that a subbie mechanic said with the scan tool connected the subbie should read 0.45-0.55 volt with the throttle completely closed. Is that true? Link to comment Share on other sites More sharing options...
Kennyfvholla Posted June 14, 2013 Share Posted June 14, 2013 The second cable is for the cruise control system Link to comment Share on other sites More sharing options...
urdrwho Posted June 14, 2013 Author Share Posted June 14, 2013 Thanks. That makes sense. Probably if I would have followed the one cable I would have found it attached to the cruise mechanism. The second cable is for the cruise control system Link to comment Share on other sites More sharing options...
Kennyfvholla Posted June 14, 2013 Share Posted June 14, 2013 No problemo Link to comment Share on other sites More sharing options...
snederhiser Posted June 14, 2013 Share Posted June 14, 2013 Hello; Remember that the TPS has an idle circuit switch built in and should be adjusted per the FSM. Resistance values can vary between units, Steven. Link to comment Share on other sites More sharing options...
